ATEAMPI said:
i just need to know each step exactly to make to set this up. then i will know if i missed a step.
right now my server easystream is running i see the scanner text displayed and the green light is on, i also need to know what to put in the server info on the line IP/DNS
then can you manually put in the info on the client for other computer to test it or do you have to report to the easystream people the name of you site to put on the list before anyone can tune in?
not sure who the "easystream people" are. you will need to share the address you created with noip service you mentioned before. there was probably some software you would need to install on a PC in your home (most likely the laptop running the easystream server). all it does is report to them (the noip software maker) your external IP (the one you use to connect to the internet).
have you tried connecting to the server using the internal IP of the other laptop like edweirdFL suggested? make sure to use the IPCONFIG like I suggested. this is your FIRST STEP
edweirdFL's advise is correct.
1. install the software
2. leave the default ports alone
3. chose the correct model of scanner
4. chose the correct com port number
5. start it
6. use the IPCONFIG command I mentioned to get the INTERNAL IP of the server PC
7. install the client on the other PC and use the IP from step 7
see if those are correct and post your findings
