fireman305
- Joined
- Jan 10, 2010
- Messages
- 5
ok i have an Ht1250 that i need to program. i am using the ribless com cable. i have used this cable and software (obtained legally) to program my Ht750's and has always worked fine. i plugged my 1250 up to program and had a bit of problems geting connection at first , then i got it to read. when i got it to read i didnt really have time to do all the programming i needed so i just closed it out. now when i go to read it all it says is "couldn't open port" and says to check all connections and see if unit is powered on. it is powered on , all connections are good. i even plugged a 750 up to make sure it was not the cable. worked like a charm.
does anyone have any advise or any idea why it wont read it? and if so how may i go about fixing it without having to put more money into motorola's already overly obese pockets?
thank you
thank you
