need help
eman893
texas
i am using arc300 to program my scanner and i tried to download and upload to my scanner but its not letting me choose USB any solutions
n5ims
The USB cable looks to the software as a Com (serial communications) port. Check "Device Manager" (you can search for it pressing Start and typing "Device Manager" in the area that says "Search programs and files"). It should show up under "Ports (COM & LPT)". It'll probably show up with a name like "USB Serial Port (COM4)". Select the Com port associated with that name (Com 4 in my example).
Hope this helps!
Butelsoftware
Dayton Hamvention
In the download windows select the correct com/usb port.
When you plug the usb cable in the PC it is assigned a com number and can be found in the windows device manager. Also make sure you installed the correct driver for your usb device.
Gommert
Butel Software
