Nerumph
Hello community! I would first like to thank you for taking the time to read through, and possibly assist with, this plea of help I have finally decided to bring to the forums!
So without further adue, here is the situation of a new repeater build I am in need of assistance with!
I have been put in charge of creating a UHF repeater system in place for a fleet of 30 Baofeng UHF radios used during various activism actions here in Cali. The main goal of our organization is to keep both sides of the activism world safe: to keep our activists from unjustly harming individuals and property, and to keep government agencies and radical opponents at bay through non-violent deescalation.
Anyhow, mini unintentional promotion of our org. aside... In order for us to meet all the goals stated above, instant and consistent communication is key; and needless to say our current simplex solution is dismal at best. Apart from the fact that our radios can barely reach different ends of some larger protest marches (something like 5-6 city blocks long at times) which is embarrassing when it occurs, we also use our system in large radius Direct Action protests from time to time, where range from one end to another of a target could be as encompassing as 5 miles in rad.
Needless to say, we are in need of a better solution. And from what I have been finding around everywhere, a repeater seems to be the key!
But first off, here is a quick and dirty diagram I made up for signal and electric pathflow for this duplex repeater:
Keep in mind alot of the descriptive content I added in to help our... less technical understand some basics in the field.
For our signal flow, here is a current list of components we have compiled into the repeater so far:
TX/ RX Transceivers: Baofeng UV-82
Duplexer: Generic UHF mini BR Duplexer (tuned to our specific TX and RX freq. by the ebay seller)
Antenna: Opek Tech UHF base station antenna
Repeater Controller: Surecom DTMF controller (Though we are considering grabbing a Raspberry PI and using ORP Once I can nail down the fundamentals down with the rest of the system.
I won't list cabling specifics in here unless someone absolutely needs it; needless to say I have punched in quite a few patch cables in addition to what is in this diagram (mainly so I was able to insert an SWR meter into the mix).
So now to the fun part. Results from a couple field tests. As far as we were able to tell with these tests, transmission range on the repeater end was not an issue at all, except when our field tester was standing at the literal feet of various skyscrapers in the testing area. The problem we are currently having is every repeater's Achilles heel: RX efficiency.
(And just as a side note, we were able to get an SWR between 1.5 and 2-ish throughout these tests)
So that is where I ask my first question to you all: Just what factors will contribute to RX efficiency? Currently, I know that the RX radio squelch sensitivity, duplexer tuning, antenna tuning, elevation of the repeater, and leadline loss will contribute to or hinder performance to the system. Is there anything else I am missing in the loop?
Is there also a resource to help me do some diagnostics between the above listed dependencies; help me flush out the system so to say?
And now I get to part two of my plea for help. I certainly am no electrical engineer and do feel like I am in just a bit over my head with wiring this repeater up to a battery system. Regardless, though, I am always willing to learn and don't mind getting my hands a bit dirty with solder. Not to mention we do need this system to be self-sufficient in remote or isolated areas (like on rooftops for instance).
So in terms of components for the electrical side of this repeater, they are as follows:
Battery: 12V, 24AH, 288WH Deep Cycle LA Battery
Solar Panel (for, again, self sustainability): http://www.ebay.com/itm/NewPowa-Hig...ash=item1c42404c56]12V, 20W, 1.6A solar panel
Solar Controller: 20A 12V Controller
TX/ RX Radio Battery Eliminators: 2X Battery Eliminators for Baofeng UV-82's
I have also added the following to the system to help with certain... power issues I came up against when I first tested the system:
Two Stepdown converters for the feeds to each battery eliminator: 12V to 7.5V, 3A converters
One Stepdown converter for the power feed for the repeater controller: 12V to 5V, 3A converter
I also am using 20AWG wire just for future-proofing the system. (adding an amplifier, higher wattage transceivers, etc).
So now some questions: will this solar system be adequate enough to re-supply this system to keep it up for, say, a week constant, with load around 40-50%?
Is the circuitry 'safe' enough to be deployed on someone's roof without deep concerns about fire or explosions?
Any recommendations to help avoid that is the case?
A couple more questions here that have been stewing in my mind over the past few days as I start to re-envision this system. One of which is: I have been looking at amplifiers for the UHF spectrum and have been contemplating adding it into the mix. My question, however, is: would it be better to acquire the amplifier first, or would it be better to go with better TX/RX radios first? Something like the Baofeng BF-9500? I know I would need to get a higher watt-spec duplexer with that for sure, but would it be worth the extra cost for the extra watts? Especially in urban environments?
Another question in relation to the field transceivers themselves. We had recently upgraded our antennas for all units from the standard rubberduck antennas to some high gain Nagoya NA 771 antennas. However alot of our field ops have complained about their... much larger bulk and we have been considering downsizing to the [url=http://www.ebay.com/itm/10x-Nagoya-NA-701-Female-Dual-Band-Antenna-For-Baofeng-UV-5R-F-V-1000-PX-888-/252119458507?hash=item3ab37da2cb:g:3VEAAOxyi3FR20za]Nagoya NA 701 for convenience sake. would this be a worthwhile sacrifice or are we loosing anything at all by downsizing?
And with that I think I am done for now with my dissertation here, heh. I look forward to hearing from you all to see what you can do to help us out over here. Thank you again for your time and I hope to hear from you soon!
Sincerely,
Nerumph
Sincerely,
Nerumph
