Need some help
scootiepob420
Fargo, ND
I am curious as to if someone can help me get all the frequencies for my area programmed off the site? Help would be appreciated!
KirumiTojo
I notice your location says you're in Fargo. Do you have a scanner capable of receiving phase 1/2 trunked frequencies? Because Fargo uses the Minnesota ARMER System that's on Phase 1
tvengr
Well Known Member
Baltimore County, MD
Which scanner are you using and do you have programming software. The Fargo site on the ARMER trunked system is simulcast which may cause receive problems depending upon your scanner and location.
northwoodsradio
What scanner are you trying to do? May be able to send a file depending on the type of scanner and then can upload to the software then plug and upload to the scanner
