New decoder for Tetra and diferents modes
asgard
UK
i use this one i'm on version 1.6.0 now ,it need more work but is a start, first it eliminate sdr# wich is a great thing. bet that was some hours spent so i'll appreciate it and wait for impovements if developer have time and want to do that. nice job.
tango20k
new version 1.6 is excellent , now i can save frequencies with respective modes . netra is also working for the very first time. decoded sound for DMR is better than DSD+, very easy to use compared as well. i no longer have to have the many stupid settings for dsd+ which making them work together is mission impossible specially if the system data are not published or if its misconfigured.
Tetra works , great sound quality . but i noticed call order is not set or maybe requires some improvement . by that i mean if you are listenining to a current call and a newer call comes it will be played rather than the current one. everything else is great indeed. thanks monerioma
daratt
Using version 1.6 and working very well... FM, ADSB, DMR, TETRA.
A wish list for further features would be;
squelch control
moving the cursor in frequency steps, rather than random tuning
ability to scan frequency list entries
ability to make a frequency list within Excel. csv format?
show colour code/talkgroup in DMR mode
Keep up the good work and thanks for all the effort put into openear.
KarlosTR
I can´t open new version 1.6 on Windows 7. Library "rtlsdr.dll" from folder #SDR I have copied. When I try open command line, system write "program too big to fit in memory". Do somebody any idea what is wrong? Previously version1.5.2 runing OK. Thank you for every idea.
hamradionl
Why you want to open rtlsdr.dll ?
inside
v1.6 only run on Windows 7 , but not detected rtl sdr , and not show any option for load iq file. Also ask put to folder rtlsdr.dll - i am use dll from Sdr#
W4KRR
Coconut Creek
I also would like to see the features listed above by daratt.
Also, the ability to select a particular tuner, in the event you have more than one connected. And the ability to work with Airspy.
And despite the graphic at the beginning of the video above, it doesn't decode P25.
KarlosTR
No no a I don´t open rtlsdr.dll, I only copied rtlsdr.dll from folder #SDR to folder where I have Open EAR. When I try run program - program not open. When try open program by command line - system writte "program too big to fit in memory" Do you have any idea where may be problem? Thank you for reply and any idea
KarlosTR
Now I try tutorial from video above and now Windows writte error mistake - aplication don´t run correctly and code on screen.
KarlosTR
I try from folder #SDR, I think, that is only for 32 bit. I am runnig on 64 bit system. Do you know where is possible download for 64 bit? This may be my mistake.
