New firmware misses certain communications on G4
MTL_Emergencies
Member++
Quebec, Canada
I upgraded my G4 to firmware 1.33 but now it's not picking up communications from dispatch (I can hear units but no answer from dispatch and I even checked with a scanner).
The system I'm trying to listen: P25 Phase II with patched talkgroups (SERAM)
I didn't have any issues with v1.31
MTL_Emergencies
Member++
Quebec, Canada
Thanks, I suspect the problem is only with patched talkgroups ("Commandements"). I can (barely) listen to units communications but I'm getting 0 calls from the Centrale.
I can hear Operations good. I was able to listen to Ibus without any issues (which is also Phase II). RSP25 works good on my end too.
mdsxfire
EDBM
Uxbridge, north of the river Thames
i always want to upgrade to the latest f/w but have learned to wait with unication as they fix some issues but create a few others, i am curious as to how much “clearer”the audio is on harris systems since that is the system my dept uses. i haven’t had any issues with that i’ve noticed but still curious
Synchro39
Montreal Quebec
i have same problem as you maybe it’s because of the pps problem you can lookup a solution in the other tread here
MTL_Emergencies
Member++
Quebec, Canada
I also had the pps problem but I fixed it as they said in the other thread, but I still have the same issue with patch talkgroups. I'll try to revert to the old firmware.
MTL_Emergencies
Member++
Quebec, Canada
I sent my pager logs to Unication and they corrected the issue under firmware 1.34. I see there is improvement of radio ID decoding on Phase II transmissions.
MTL_Emergencies
Member++
Quebec, Canada
Basically I couldn't hear my dispatch on Phase II patch talkgroups.
