New Linn County P25 HELP
CA58
Iowa
I made all the frequencies MOT, none FM/P25.. I am using Win96 and ARC96. Both are working with MOT for all the frequencies and the table as noted above. Hope this helps.
Joe W0MJN
Could you expand on the process. I see one line of settings for 9600 but in ARC 96 there are more than one line... do I delete all the others??? How about the 3600 settings? Normal or Multi table???
I am right back where I was at first.... scanner display showing properly.... no sound
Why can't anyone put a STEP BY STEP procedure that has worked for the PRO - 96. How hard is that for someone who has figured it out TO DO. ???? Evidently pretty difficult.
CA58
Iowa
Okay.... In ARC 96 I deleted all other info in multi tables (value 0) this was under the 9600 side. left the 3600 side as is (Normal). In the 9600 I inserted the single line of codes 0,4095,0,851.01250,12.50 I went to config and unchecked "show id#"
My pro-96 is now working properly. It will now actually work on the open /closed bank mode. (Before it didn't matter open or closed I was receiving traffic from TG's that weren't even in radio.lol) Now shows alpha tags .... not TGID#'s. YEAAAAAAAAAAAAAAAAA! I still get some garbled talk... I don't know if from to strong or to weak of signal. I guess it's normal from what I have read here.
jfinkstein
Marion, IA
The garble could likely be an encrypted channel,
BobU05
Well after about a week of listening to my scanner with the updates and new scan lists, it seems to be working pretty well. I would say I hear about 90% of the traffic now, this is with the radio shack antenna. I found a good spot to put the scanner where I see the best results. So far so good.
ylekiot51
Cedar Rapids, Iowa - near Robins, IA
Thanks for the Pro-96 Help!
Eureka!!! My Pro-96 works! Thanks, CA58, for the clarification of your process!
And thanks to everyone here for their support along the way!
IowaGuy1603
Jones County Iowa
Good..............................90% for being in Marion is pretty good. I get a bit less than that when I am mobile through town
kjauron1
Cedar Rapids, Iowa
still nothing
I am still with a 396XT and 996XT paper weights....I uploaded the RR files onto my 996 friday and drove all through Marion, Cedar Rapids, and Hiawatha. I never received any audio at all. WHAT AM I DOING WRONG???
If anyone has files I can try, I would greatly appreciate it!
timkilbride
Linn Co Iowa
Did you have your squelch level set to "2" ? Anything higher won't work.
Tim
ferd1605
Cedar Rapids , Ia.
am still having problems getting the new system . at times in the house with the pro-197 I can hear fine , but most of the time it's garbled & broken up , tried the outside antenna and one inside & still the same . Once it warms up I plan on building a corner reflector antenna & point it to the site near Wilson & 6th st. ( am in Cedar Hills ) . the 396T in the mobile is same way , hit & miss with either the Radio Shack 800mhz duckie out the 800mhz mag. mount on the roof , but 95% copy if I am on the SW side of town .. could my problems be from picking up multible sites at same time or scanner programing ?
IowaGuy1603
Jones County Iowa
multipath interference ...................
If it works sometimes............you have it programed correctly.
Actually if you are in Cedar Hills I would experiment with aiming toward the DAEC tower
You are probably 1/2 way or so between the Wilson Ave & DAEC towers...........not going to be fun without a VERY directional antenna
tsinmw
Cedar Rapids, IA
SW Side, Pro-197. After forking out about $100 for a 900mhz yagi antenna, 50' of good quality low loss cable,and crawling around a hot attic, I am now receiving about 98% of tx's.
timkilbride
Linn Co Iowa
Mileage will vary case to case. In your case, it sounds like it is working well. On the flip side, I have some people getting really good decode and then 2 days later they have to "fiddle" with their beam to get that good decode back.
Tim
IowaGuy1603
Jones County Iowa
Tim
There are days when my decode rate goes down to maybe 90% here at home---most of the time around 98% NE of Martelle as long as I stay on the stock Ducky antenna that came with the PSR 800.
If I hook it to an outside antenna it goes down to 80% or worse
Mobile is terrible on the SW side and in Marion................95% and better downtown, NE and close in SE
using an outside DUCKY mag mounted to the roof on an extender cable
bar422
When I was there a few weeks ago my 536HP was sounding crystal clear the whole time I was there.....and it was sitting in a cupholder using the stock duck antenna........maybe I just got lucky!
n0akf
Waterloo, IA
Are you still able to use your 396T in the Cedar Rapids area?
