BC125AT: New program BC125AT
SharonLDurham
I have a new uniden BC125AT why is the screen having a glitch in the screen writing? How do I unlock it? How do I program it for a Nascar Race?
SharonLDurham
Welcome to the RR forums. You can either program a BC125AT by hand (start on page 37 of the manual) or by using software like Proscan. Expect a bit of a learning curve if you have little to no experience programming scanners but plenty of resources at your disposal right here on the Uniden forums.
Thank You Sharon! My main problem is that it is new with a glitch in the writing on main screen would like to fix that and get it working before Nascar race.
Ronaldski
MI DB Admin
Bay City MI
programming, plenty of youtube videos, here are a few
Uniden BC125AT Programming
murphcc1
Another programming software I use is ......https://www.butel.nl/products/arc125/arc125.html
D31245
FN42
Have you tried a reset?
To reset the Uniden BC125AT, turn off the scanner, then press and hold the 2, 9, and HOLD keys while turning the scanner back on. This will clear all data and return the scanner to its initial settings.
I also use the Unden software program my BC125AT. Works fine.
  • Like
Reactions: wtp
SharonLDurham
I have i am all good other then a glitch in the screen where you see the writing. I need some one local to program mine.
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
ummm...unless I'm reading that display wrong, it says 'charging'....guess what that means?
MIke
wtp
Port Charlotte FL
sent it as a PM also.
i thought i was here...this is for any others
Adjusting the Contrast
This submenu of the Display/Charge menu controls the display’s contrast (how light or dark it appears) for different viewing conditions. There are 15 contrast settings. You see the contrast change as you scroll through the settings.
1. To adjust the contrast, press Func then ; the Display/ Charge menu displays
2. Scroll to Set Contrast and press Pgm/E.
3. Scroll to see the contrast settings.
4. When you have selected a setting, press Pgm/E to set it and return to the previous menu.
5. Press . Clr to exit.
and many here like proscan
there is a free trial
