They have only been up on MOL for a day or two:
Commercial Series CPS_NA_R05.17
Professional Series_CPS_R06.12.08
Be aware! These releases specifically address 12.5 Khz. spacing. If I understand the release notes correctly, these versions will not allow 20.0 or 25.0 KHz spacing. Once you have programmed a radio using these latest versions, there's no going back.
I am discovering that it might be advantageous to have a receive only channel at 25 KHz in our radios on at least one of the primary EMS frequencies in our area. We're not sure that the county had the EMS base radios properly narrowbanded because they sound like crap now. The fire channels which are the same model base radios sound just fine on the same mobiles, portables, and pagers. (EMS is a bit of an orphan child up here, it seems.)
If I were to install these latest versions, I don't think I would be able to retain a 25 Khz receive only channel in the radios. Right now that might not be a wise move. Others may want to consider this before upgrading.
