New TAFL Search
jfroot
I have created an alternate TAFL Search tool at the following address:
http://www.jrmy.net/tafl
This will allow you to search allocated frequencies across Canada. It is still in the beta phase, so let me know if you think it needs any improvement.
Biggest difference to the government version and others is you can put in your postal code and a radius and see all licensed transmitters within that radius. This lets you see whats close to your house for best listening etc.
J
torontokris
Toronto Canada
Dont forget to remind people NOT to put a space in the postal code.. or else no results show up
Other then that it looks great
torontokris
Toronto Canada
Could add a way to search for all local results (if you dont know the name)
i.e. ALL results within 1km of my postal code
At the moment you have to enter something in the "SEARCH" field.. you cant just do a wildcard
jfroot
I have made the change so spaces in postal codes now work.
As far as wanting to search for everything around you, that should work. If you put in your postal code and set a radius of 10km you should see something if you leave search blank. Perhaps your postal code is not geo-locating properly. Post it here and I can test it out.
J
FastEddie
Dudas
I typed in McMaster and the frequencies poped up- GREAT! Then I typed "police", OPP, Railroad and nothing. Am I doing something wrong or expecting too much??
Saint
Fort Erie Ontario Canada
police
As far as I know the police and OPP frequencies are not in the Talf lists and some other frequencies.
Steve
IdleMonitor
The Ottawa Valley - Eastern Ontario
Law Enforcement isn't in the database. It clearly states that.
"Frequencies for law enforcement, military and other sensitive organizations are not included in the database."
jfroot
Added:
Per Column sorting (click on the column header)
Postal code validation (Radius wont activate until a valid postal code is entered)
Wildcards (*), quotations, + and - now work in search box.. like a normal search engine
To Do:
Make Google maps popup in a cure little window and not take up whole frame
Fix Column sorting.. when you switch column to sort on it reverses instead of defaulting to ascending
Any other requests?
jfroot
DaveH
Ottawa, Ont.
Good tool to add to our kit of search utilities.
Just an observation, in the frequency range, spaces are need between
frequencies and the "-" separator. No problem.
Dave
slicerwizard
Toronto, Ontario
When I search for "Fleetcom", only 19% of the records are returned.
And every license is listed twice (with TX and RX swapped)
jfroot
There are only 42 records in the raw TAFL database from IC that have the string Fleetcom in it.
And the raw data has the entries you mentioned with reversed rx and tx.. I cannot say why. I just use the raw data from IC.
| rx | tx | name | loc |
| 937650000 | 898650000 | Fleetcom Digital I | BURNABY BC 6240 MCKAY AVENUE |
| 937675000 | 898675000 | Fleetcom Digital I | BURNABY BC 6240 MCKAY AVENUE |
| 937700000 | 898700000 | Fleetcom Digital I | BURNABY BC 6240 MCKAY AVENUE |
| 937725000 | 898725000 | Fleetcom Digital I | BURNABY BC 6240 MCKAY AVENUE |
| 937900000 | 898900000 | Fleetcom Digital I | SURREY BC 13880 101 AVENUE |
| 937925000 | 898925000 | Fleetcom Digital I | SURREY BC 13880 101 AVENUE |
| 937950000 | 898950000 | Fleetcom Digital I | SURREY BC 13880 101 AVENUE |
| 937975000 | 898975000 | Fleetcom Digital I | SURREY BC 13880 101 AVENUE |
| 938150000 | 899150000 | Fleetcom Digital I | MT SEYMOUR BC CHUM SITE |
| 938175000 | 899175000 | Fleetcom Digital I | MT SEYMOUR BC CHUM SITE |
| 938200000 | 899200000 | Fleetcom Digital I | MT SEYMOUR BC CHUM SITE |
| 938225000 | 899225000 | Fleetcom Digital I | MT SEYMOUR BC CHUM SITE |
| 898650000 | 937650000 | Fleetcom Digital I | BURNABY BC 6240 MCKAY AVENUE |
| 898675000 | 937675000 | Fleetcom Digital I | BURNABY BC 6240 MCKAY AVENUE |
| 898700000 | 937700000 | Fleetcom Digital I | BURNABY BC 6240 MCKAY AVENUE |
| 898725000 | 937725000 | Fleetcom Digital I | BURNABY BC 6240 MCKAY AVENUE |
| 898900000 | 937900000 | Fleetcom Digital I | SURREY BC 13880 101 AVENUE |
| 898925000 | 937925000 | Fleetcom Digital I | SURREY BC 13880 101 AVENUE |
| 898950000 | 937950000 | Fleetcom Digital I | SURREY BC 13880 101 AVENUE |
| 898975000 | 937975000 | Fleetcom Digital I | SURREY BC 13880 101 AVENUE |
| 899150000 | 938150000 | Fleetcom Digital I | MT SEYMOUR BC CHUM SITE |
| 899175000 | 938175000 | Fleetcom Digital I | MT SEYMOUR BC CHUM SITE |
| 899200000 | 938200000 | Fleetcom Digital I | MT SEYMOUR BC CHUM SITE |
| 899225000 | 938225000 | Fleetcom Digital I | MT SEYMOUR BC CHUM SITE |
| 937618750 | 898618750 | Fleetcom Alberta I | CALGARY, AB. INTL AIRPORT |
| 937643750 | 898643750 | Fleetcom Alberta I | CALGARY, AB. INTL AIRPORT |
| 937668750 | 898668750 | Fleetcom Alberta I | CALGARY, AB. INTL AIRPORT |
| 937693750 | 898693750 | Fleetcom Alberta I | CALGARY, AB. INTL AIRPORT |
| 898618750 | 937618750 | Fleetcom Alberta I | CALGARY, AB. INTL AIRPORT |
| 898643750 | 937643750 | Fleetcom Alberta I | CALGARY, AB. INTL AIRPORT |
| 898668750 | 937668750 | Fleetcom Alberta I | CALGARY, AB. INTL AIRPORT |
| 898693750 | 937693750 | Fleetcom Alberta I | CALGARY, AB. INTL AIRPORT |
| 459587500 | 454587500 | Fleetcom Inc. | TORONTO, ONT. 500 DUPLEX AVE |
| 454587500 | 459587500 | Fleetcom Inc. | TORONTO, ONT. 500 DUPLEX AVE |
| 467537500 | 462537500 | Fleetcom Inc. | TORONTO, ONT. 500 DUPLEX AVE |
| 468137500 | 463137500 | Fleetcom Inc. | TORONTO, ONT. 500 DUPLEX AVE |
| 462537500 | 467537500 | Fleetcom Inc. | TORONTO, ONT. 500 DUPLEX AVE |
| 463137500 | 468137500 | Fleetcom Inc. | TORONTO, ONT. 500 DUPLEX AVE |
| 936593750 | 897593750 | Fleetcom Inc. | OAKVILLE, 1359 WHITE OAKS BLVD |
| 936618750 | 897618750 | Fleetcom Inc. | OAKVILLE, 1359 WHITE OAKS BLVD |
| 897593750 | 936593750 | Fleetcom Inc. | OAKVILLE, 1359 WHITE OAKS BLVD |
| 897618750 | 936618750 | Fleetcom Inc. | OAKVILLE, 1359 WHITE OAKS BLVD |
42 rows in set (4.24 sec)
slicerwizard
Toronto, Ontario
There are 220 raw records that contain that string.
C:\TAFL2008>findtext "fleetcom" tafl??.txt >nul
38 files found.
file: C:\TAFL2008\TAFL23.TXT
<1 match in 12,137 lines>
file: C:\TAFL2008\TAFL24.TXT
<1 match in 13,026 lines>
file: C:\TAFL2008\TAFL25.TXT
<2 matches in 11,771 lines>
file: C:\TAFL2008\TAFL26.TXT
<2 matches in 16,030 lines>
file: C:\TAFL2008\TAFL30.TXT
<107 matches in 23,447 lines>
file: C:\TAFL2008\TAFL31.TXT
<107 matches in 14,089 lines>
<Total: 220 matches in 570,477 lines in 6 files out of 38 files>
Because IC uses separate records for TX and RX data (like antenna height). It's in their docs. IMO, one should not report records that are exact duplicates with the exception of TX and RX being reversed.
Code:
TAFL-TS  Rev 4.0  (c) 1997-2006, W. A. Porrett
Searching database for 'FLEETCOM'
DO      TX         RX     User Name           Location                             ID
42   454.5875   459.5875  Fleetcom Inc.       TORONTO, ONT. 500 DUPLEX AVE         XKU256
42   462.5375   467.5375  Fleetcom Inc.       TORONTO, ONT. 500 DUPLEX AVE         XKU256
42   463.1375   468.1375  Fleetcom Inc.       TORONTO, ONT. 500 DUPLEX AVE         XKU256
42   936.5750   896.5750  Fleetcom Inc.       NORTH YORK, ONT. 10 TANGREEN CRT     CIK485
42   936.14375  897.14375 Fleetcom Inc.       MISSISSAUGA, ONT. LPBIA, S AMF BLDG  CIK488
42   936.16875  897.16875 Fleetcom Inc.       MISSISSAUGA, ONT. LPBIA, S AMF BLDG  CIK488
42   936.19375  897.19375 Fleetcom Inc.       MISSISSAUGA, ONT. LPBIA, S AMF BLDG  CIK488
42   936.21875  897.21875 Fleetcom Inc.       MISSISSAUGA, ONT. LPBIA, S AMF BLDG  CIK488
42   936.59375  897.59375 Fleetcom Inc.       AJAX, ONT. 50 EXETER RD              CIQ998
42   936.59375  897.59375 Fleetcom Inc.       NORTH YORK, ONT. 10 TANGREEN CRT     CIK486
43   936.59375  897.59375 Fleetcom Inc.       OAKVILLE, 1359 WHITE OAKS BLVD       VDS729
42   936.61875  897.61875 Fleetcom Inc.       AJAX, ONT. 50 EXETER RD              CIQ998
42   936.61875  897.61875 Fleetcom Inc.       NORTH YORK, ONT. 10 TANGREEN CRT     CIK486
43   936.61875  897.61875 Fleetcom Inc.       OAKVILLE, 1359 WHITE OAKS BLVD       VDS729
42   936.70625  897.70625 Fleetcom Inc.       KING CITY, ON 200 KING SUMMIT RD.    CIY601
42   936.70625  897.70625 Fleetcom Inc.       MISSISSAUGA - 2990 BATTLEFORD RD.    VFC241
42   936.70625  897.70625 Fleetcom Inc.       MISSISSAUGA, ONT. LBPIA HARMONY DAS  CIK483
42   936.70625  897.70625 Fleetcom Inc.       TORONTO, ONT. 21 AVENUE RD           CIK484
42   936.73125  897.73125 Fleetcom Inc.       KING CITY, ON 200 KING SUMMIT RD.    CIY601
42   936.73125  897.73125 Fleetcom Inc.       MISSISSAUGA - 2990 BATTLEFORD RD.    VFC241
42   936.73125  897.73125 Fleetcom Inc.       MISSISSAUGA, ONT. LBPIA HARMONY DAS  CIK483
42   936.73125  897.73125 Fleetcom Inc.       TORONTO, ONT. 21 AVENUE RD           CIK484
42   936.75625  897.75625 Fleetcom Inc.       220 OAK STREET, TORONTO              VFQ243
42   936.75625  897.75625 Fleetcom Inc.       4 HANOVER ROAD, BRAMPTON, ONTARIO    VFX213
42   936.75625  897.75625 Fleetcom Inc.       MISSISSAUGA, ONT. LBPIA HARMONY DAS  CIK483
42   936.78125  897.78125 Fleetcom Inc.       220 OAK STREET, TORONTO              VFQ243
42   936.78125  897.78125 Fleetcom Inc.       4 HANOVER ROAD, BRAMPTON, ONTARIO    VFX213
42   936.78125  897.78125 Fleetcom Inc.       MISSISSAUGA, ONT. LBPIA HARMONY DAS  CIK483
42   936.8000   897.8000  Fleetcom Inc.       TORONTO, ONT. 500 DUPLEX AVE         CFT762
42   936.8125   897.8125  Fleetcom Inc.       TORONTO, ONT. 500 DUPLEX AVE         CFT762
42   936.8250   897.8250  Fleetcom Inc.       TORONTO, ONT. 500 DUPLEX AVE         CFT762
42   936.9000   897.9000  Fleetcom Inc.       TORONTO, ONT. 500 DUPLEX AVE         CFT762
42   936.9125   897.9125  Fleetcom Inc.       TORONTO, ONT. 500 DUPLEX AVE         CFT762
42   937.91875  897.91875 Fleetcom Inc.       SCARBOROUGH, ONT. 100 WINGARDEN CRT  CGO733
42   936.9250   897.9250  Fleetcom Inc.       TORONTO, ONT. 500 DUPLEX AVE         CFT762
42   936.9500   897.9500  Fleetcom Inc.       TORONTO, ONT. 500 DUPLEX AVE         CFT762
42   936.9625   897.9625  Fleetcom Inc.       TORONTO, ONT. 500 DUPLEX AVE         CFT762
42   937.5125   898.5125  Fleetcom Inc.       TORONTO, ONT. 500 DUPLEX AVE         CFT762
42   937.51875  898.51875 Fleetcom Inc.       MISSISSAUGA, ONT. LBPIA HARMONY DAS  CIK483
42   937.5250   898.5250  Fleetcom Inc.       TORONTO, ONT. 500 DUPLEX AVE         CFT762
42   937.5375   898.5375  Fleetcom Inc.       TORONTO, ONT. 500 DUPLEX AVE         CFT762
42   937.54375  898.54375 Fleetcom Inc.       MISSISSAUGA, ONT. LBPIA HARMONY DAS  CIK483
42   937.5500   898.5500  Fleetcom Inc.       TORONTO, ONT. 500 DUPLEX AVE         CFT762
42   937.5625   898.5625  Fleetcom Inc.       TORONTO, ONT. 500 DUPLEX AVE         CFT762
42   937.56875  898.56875 Fleetcom Inc.       MISSISSAUGA, ONT. LBPIA HARMONY DAS  CIK483
42   937.5750   898.5750  Fleetcom Inc.       TORONTO, ONT. 500 DUPLEX AVE         CFT762
42   937.5875   898.5875  Fleetcom Inc.       TORONTO, ONT. 500 DUPLEX AVE         CFT762
42   937.59375  898.59375 Fleetcom Inc.       MISSISSAUGA, ONT. LBPIA HARMONY DAS  CIK483
42   937.6000   898.6000  Fleetcom Inc.       TORONTO, ONT. 500 DUPLEX AVE         CFT762
23   937.61875  898.61875 Fleetcom Alberta I  CALGARY, AB. INT'L AIRPORT           VFU749
42   937.61875  898.61875 Fleetcom Inc.       MARKHAM, ON 25 AUSTIN DRIVE          VFY242
42   937.61875  898.61875 Fleetcom Inc.       MISSISSAUGA, ONT. 3650 KANEFF CRES   CGO732
42   937.61875  898.61875 Fleetcom Inc.       MISSISSAUGA, ONT. LBPIA HARMONY DAS  CIK483
23   937.64375  898.64375 Fleetcom Alberta I  CALGARY, AB. INT'L AIRPORT           VFU749
42   937.64375  898.64375 Fleetcom Inc.       MARKHAM, ON 25 AUSTIN DRIVE          VFY242
42   937.64375  898.64375 Fleetcom Inc.       MISSISSAUGA, ONT. 3650 KANEFF CRES   CGO732
42   937.64375  898.64375 Fleetcom Inc.       MISSISSAUGA, ONT. LBPIA HARMONY DAS  CIK483
12   937.6500   898.6500  Fleetcom Digital I  BURNABY BC 6240 MCKAY AVENUE         VX9DEV
23   937.66875  898.66875 Fleetcom Alberta I  CALGARY, AB. INT'L AIRPORT           VFU749
42   937.66875  898.66875 Fleetcom Inc.       MISSISSAUGA, ONT. LBPIA HARMONY DAS  CIK483
42   937.66875  898.66875 Fleetcom Inc.       TORONTO, ONT. 500 DUPLEX AVE         XKH953
12   937.6750   898.6750  Fleetcom Digital I  BURNABY BC 6240 MCKAY AVENUE         VX9DEV
23   937.69375  898.69375 Fleetcom Alberta I  CALGARY, AB. INT'L AIRPORT           VFU749
42   937.69375  898.69375 Fleetcom Inc.       MISSISSAUGA, ONT. LBPIA HARMONY DAS  CIK483
42   937.69375  898.69375 Fleetcom Inc.       TORONTO, ONT. 500 DUPLEX AVE         XKH953
12   937.7000   898.7000  Fleetcom Digital I  BURNABY BC 6240 MCKAY AVENUE         VX9DEV
42   937.7125   898.7125  Fleetcom Inc.       MISSISSAUGA, ONT. 5915 AIRPORT RD    VAF845
42   937.71875  898.71875 Fleetcom Inc.       TORONTO ON 4001 STEELES AVE W        VFY467
12   937.7250   898.7250  Fleetcom Digital I  BURNABY BC 6240 MCKAY AVENUE         VX9DEV
42   937.74375  898.74375 Fleetcom Inc.       TORONTO ON 4001 STEELES AVE W        VFY467
42   937.76875  898.76875 Fleetcom Inc.       MISSISSAUGA, ONT. 20 CHERRYTREE DR   XKH952
42   937.76875  898.76875 Fleetcom Inc.       SCARBOROUGH - 31 GILDER AVE.         CFT844
42   937.79375  898.79375 Fleetcom Inc.       MISSISSAUGA, ONT. 20 CHERRYTREE DR   XKH952
42   937.79375  898.79375 Fleetcom Inc.       SCARBOROUGH - 31 GILDER AVE.         CFT844
42   937.81875  898.81875 Fleetcom Inc.       MISSISSAUGA, ONT. 20 CHERRYTREE DR   XKH952
42   937.84375  898.84375 Fleetcom Inc.       OSHAWA, ONT. 255 SIMCOE ST N         CIK487
42   937.84375  898.84375 Fleetcom Inc.       RICHMOND HILL - 34 CENTRE ST. WEST   VFC242
42   937.84375  898.84375 Fleetcom Inc.       TORONTO, ON 35 VIKING RD             VFZ809
42   937.86875  898.86875 Fleetcom Inc.       OSHAWA, ONT. 255 SIMCOE ST N         CIK487
42   937.86875  898.86875 Fleetcom Inc.       RICHMOND HILL - 34 CENTRE ST. WEST   VFC242
42   937.86875  898.86875 Fleetcom Inc.       TORONTO, ON 35 VIKING RD             VFZ809
42   937.89375  898.89375 Fleetcom Inc.       MISSISSAUGA, ONT. 5915 AIRPORT RD    VAF845
42   937.89375  898.89375 Fleetcom Inc.       SCARBOROUGH, ONT. 100 WINGARDEN CRT  CGO733
12   937.9000   898.9000  Fleetcom Digital I  SURREY BC 13880 101 AVENUE           VX9DEU
42   937.91875  898.91875 Fleetcom Inc.       MISSISSAUGA, ONT. 5915 AIRPORT RD    VAF845
12   937.9250   898.9250  Fleetcom Digital I  SURREY BC 13880 101 AVENUE           VX9DEU
42   937.94375  898.94375 Fleetcom Inc.       MISSISSAUGA, ONT. 5915 AIRPORT RD    VAF845
12   937.9500   898.9500  Fleetcom Digital I  SURREY BC 13880 101 AVENUE           VX9DEU
42   937.96875  898.96875 Fleetcom Inc.       MISSISSAUGA, ONT. 5915 AIRPORT RD    VAF845
12   937.9750   898.9750  Fleetcom Digital I  SURREY BC 13880 101 AVENUE           VX9DEU
42   937.99375  898.99375 Fleetcom Inc.       MISSISSAUGA, ONT. 5915 AIRPORT RD    VAF845
12   938.1500   899.1500  Fleetcom Digital I  MT SEYMOUR BC CHUM SITE              VX9DET
12   938.1750   899.1750  Fleetcom Digital I  MT SEYMOUR BC CHUM SITE              VX9DET
12   938.2000   899.2000  Fleetcom Digital I  MT SEYMOUR BC CHUM SITE              VX9DET
12   938.2250   899.2250  Fleetcom Digital I  MT SEYMOUR BC CHUM SITE              VX9DET
42   938.68125  899.68125 Fleetcom Inc.       ETOBICOKE - 10 MARKBROOK LANE        VFC273
42   938.70625  899.70625 Fleetcom Inc.       ETOBICOKE - 10 MARKBROOK LANE        VFC273
42   939.06875  900.06875 Fleetcom Inc.       TORONTO, ONT. 380 DIXON RD.          CIL998
42   939.09375  900.09375 Fleetcom Inc.       TORONTO, ONT. 380 DIXON RD.          CIL998
42   939.33125  900.33125 Fleetcom Inc.       BALLANTRAE, ONT. 3621 AURORA RD      CZD219
42   939.33125  900.33125 Fleetcom Inc.       TORONTO, ON 245 DUNN AVE             VFC240
42   939.35625  900.35625 Fleetcom Inc.       BALLANTRAE, ONT. 3621 AURORA RD      CZD219
42   939.35625  900.35625 Fleetcom Inc.       TORONTO, ON 245 DUNN AVE             VFC240
42   939.39375  900.39375 Fleetcom Inc.       MISSISSAUGA ON - 5444 DIXIE RD.      VXA428
42   939.41875  900.41875 Fleetcom Inc.       MISSISSAUGA ON - 5444 DIXIE RD.      VXA428
42   939.44375  900.44375 Fleetcom Inc.       MISSISSAUGA ON - 5444 DIXIE RD.      VXA428
42   939.46875  900.46875 Fleetcom Inc.       MISSISSAUGA ON - 5444 DIXIE RD.      VXA428
42   939.9125   900.9125  Fleetcom Inc.       MISSISSAUGA, ONT. 20 CHERRYTREE DR   XKH952
42   939.9250   900.9250  Fleetcom Inc.       MISSISSAUGA, ONT. 20 CHERRYTREE DR   XKH952
42   939.9375   900.9375  Fleetcom Inc.       MISSISSAUGA, ONT. 20 CHERRYTREE DR   XKH952
Out of 318,742 entries, 110 match search parameters.
