I do plan getting a high gain antenna soon. Long boom length and a lot of elements. I stumbled across this old vhf antenna one afternoon and said to myself that I could use it for my radio antenna and play around with thAt until I actually purchased a good one. So I asked the people before they scrapped it if I could have it. They said yes.
One thing is for certain, when I build a stick antenna I want a high dB gain omni something like a collinear 3 element made of copper tubing. I have been reading some interesting things about them. I'm not going to jump right into antennas because my real passion is understanding radios and what goes on inside of them. I will try to stay focused on that. All I like is one piece of test equipment or so to begin my journey.
Time for me to go to sleep. I got to get some rest before this baby is born. I'm at the labor and delivery center and she is dilated to 8 cm. Won't be long. Wish us luck, 73's.
KM4IXU
First off Congrats Dad!!!
Check out the Verticals from Diamond and Comet. They both provide excellent products and their customer service after the sale is first rate.
Another company makes a copy of the Diamond/Comet verticals and their name is Tram-Browning basically their products sell for about 1/2 the retail price of Diamond and Comet. I use several Comets and also have Diamond antennas on my mobiles.
I have used the Tram-Browning antennas and they work well, although structurally they aren't built as solidly as the other brands. I have some friends who love them and they fit into budgets a little easier.
My Comet GP 9 has what many call ridiculous ratings and the TB brand claims similar specs as well. I share net operator duties in a twice weekly multi state VHF SSB net along with some other ops and they also run the higher gain verticals. Some run M2 beams, others use Cubic Quads, I use INNOV and M2 while others use home brew antennas.Cushcraft, Hygain, ELk, Arrow and others all find use in this net.
I love building antennas, especially if a new licensed Amateur locally can benefit from sharing the building experience and then use the antenna. All in all I build more HF antennas than VHF/UHF about 2:1 on average. You are lucky to have several knowledgeable hams on this forum like K7MEM, W9BU ( a lot of experience in repeaters and VHF/UHF from his QRZ page), KB5ZCS just to list a few who have commented. Keep experimenting, check out as many shacks as you can keep your eyes and ears open, you will quickly learn a lot and especially application of theory not just theory alone.
With VHF and UHF SSB it is both similar and at the same time more challenging than SSB on HF. Sometimes the band is so quiet you wonder if anyone is ever on and other times it opens, some Tropo happens and you are in a QSO running 10 watts and some op in Hawaii is on the other end. Don't forget or stay off of 6 Meters as it can be the same way suddenly open for serious DX and other times if repeaters weren't there you find yourself asking does anyone EVER use this band??
Check out MOXON antennas, very easy to build, lightweight, fantastic rejection but leaves a bit to be desired in forward gain compared to some other designs. There are always trade offs and sometimes the little less gain along with the rejection works out better than a lot of gain and less rejection. I've built Moxons to cover 20meters through UHF frequencies. A roll of copper tubing ( like you use to connect a Fridge ice/water hook up) some PVC and an SO-239 connector is almost all you need to construct one. I have even used some old furring strips, wire a couple of pieces of plastic and feed it directly to the driven element. They don't weigh much and you can make them cheap enough to have several in fixed positions if you like and have the room. One fellow Ham and I made enough to cover several fixed positions for 40,20,17 and 6 meters. He has a lot of acreage so he can have an antenna farm. IF you want to rotate them they are usually very light weight (depending on materials used) to be turned by hand or using a light to medium duty rotator.
As for verticals you can get the parts for a very nice fiberglass one 31 feet or use military masting and go longer. very simple to make, add a good balun and tuner for the bands it needs a bit of help on and you have a great vertical for 80-6 meters and you can even take it backpacking if you use the collapsing pole type. Think of Jack-Kite poles for example of one source. The military masting can be carried but is more bulky and heavier to handle.
Hope that adds to your ideas list.
