surfacemount
It won't do ADP? That's a deal breaker
I am sure the 200 will. Are there any other sleeper harris multibands that will?
The XL-200 will. I ordered it with ours. 1¢ option. They refer to it as "Encryption Lite". It's ARC4….
That just means you haven't looked hard enough. There is probably a copy waiting for you right under the snow. Or you could wait till spring.You won't find hacked versions of RPM2 floating around like you see with RPM14. So if you're wanting to use it for trunked systems etc it's going to be tough going.
I still haven't found 14c05 yet, so you may be right about RPM2Depends on your usage. In a legit public safety/work environment with a licensed copy of RPM2 they are a great radio at a cheaper cost of an APX.
For a hobbyist, not so practical. You won't find hacked versions of RPM2 floating around like you see with RPM14. So if you're wanting to use it for trunked systems etc it's going to be tough going.
Any pitfalls or reasons (besides cost) not to get an XL-200? I am trying to figure out all the model numbers now.
The RPM2 software is licensed to the installation, so I'm not aware of any way to bootleg it. It's not cheap, either. $895 list price.
I've been told that bootleg versions of RPM2 exist, as well as ways to update the radio feature strings.
I can't help you there. I do this stuff professionally and I have no need/desire to go looking for it. There's much more value for me to have legit copies that I can get updated easily and not worry about where its coming from. Hobby use? Maybe they're OK with that.
I understand. I worked briefly in a place where everything that touched a radio needed to be traceable. There was absolutely no 'get er done', we literally had to call engineers to approve minor deviations and rework. Not so much as a fabbed cable connection.
But I grew up in the era of the pirate bay and radios with replaceable components, so
LTE is apparently an add on option for the 200. Is that field installable? I am guessing you're really at the mercy of finding a citizen/ham friendly service shop, no way they give someone a TAC account just for buying one subscriber unit?
Oh.I ordered ours with the LTE option, came from the factory that way. It may be something a shop can add, but I've never seen it available separately. It would require updating the feature set of the radio to support it. The physical LTE module is a bulge on the top back of the radio above the battery. It adds some size to the radio, but isn't any thicker than the larger battery pack. LTE/WiFi antennas are internal. Mobile, its all internal with two LTE and two WiFi antenna ports on the VCH. I've got mine connected to a blade WiFi/LTE/GPS antenna on the roof of the truck.
There's only two uses for it:
1. BeON, which is the L3Harris LTE/WiFi product that connects voice over LTE or WiFi to the P25 Core. Unless you have the P25 Core and the BeON servers, it won't do anything with voice. It will not work as a cell phone. Not something that is useful to a hobbyist.
2. As someone here once said "Worlds most expensive WiFi hot spot". It'll allow the LTE data to pass to the WiFi and can create a local WiFi hotspot.
BeON, if you have the whole setup, is a pretty sweet solution. If you get out of range of the system, it'll fall back on LTE or WiFi to connect back into the P25 core. I know one agency that is using BeON as their primary communications, fall back to UHF conventional, fall back from that to their County P25 system. LTE has better building penetration than the other systems, so it works well in urban/suburban areas.
I ordered it for our officers as the long term plan is to put them on a P25 system, and allow them to fall back on WiFi or LTE if they get out of coverage.
I like documentation lol. And training. I've had a MOL account for years, but even with a .gov email and harris products had issues getting a harris account. (long story)TAC account won't do much for you. It's mainly documentation and opening support tickets.
Oh.
I was thinking it was for competing with APX Next in using firstnet for backbone. Didn't even think about it being a cell phone, but I can see how that might be inferred.
