Hello all, new to radio, just beginning. Always liked tinkering with radios and figured be fun to learn and do.
In the beginning stages of learning the material for the license test, and bought a handheld triband radio from a Amazon. A mirkit/baofeng unit. (Also have a triband antenna and usb cable incoming. As for the radio yes it’s a baofeng, but figured I’d rather learn the basics, and fiddle with a $30 cheapie at first before migrating up to say a Icom or Yaesu. So $30 bucks if I Bork something not as much of a loss. Currently don’t have any plans to go beyond handheld, nor set up a elaborate base station with a antenna array. I do intend to eventually get all 3 licenses however. Soooo most likely will be spending some time poking around the forums and rooting out info to prepare for the exams and such. Tinker with stations and frequencies to listen in, sometimes it’s fun to just scan and listen to what’s out there. So yeah another case of me just diving headfirst into something 😅
I do have a immediate question until my tri band antenna arrives. The baofeng came with two antennas, with different noted frequency ranges on them. Is there damage risk if day I float to a frequency outside of said installed antenna’s range? Or is it just signal would go wonky?
