TwoToneDetect New TwoToneDetect in the works - Python based
Ashes80
Ok set input/output @ 3 grabbed the latest version like you suggested. Noticed it didn't come with a level meter so you are prob right about the "3" setting. Now just try to run TwoToneDetect and starts with what looks like the same info the previous screenshot and fails with the same error....
"FATAL: cannot locate cpu MHz in /proc/cpuinfo"
Frustrating !
DC31
Massachusetts
Frustrating !
Ashes, I saw your post in the raspberrypi.org forums also. See your private messages in this forum for a link and see if it helps out.
Jim
aaknitt
Disregard my above post.
Is there a maximum number of recipients for a tone set in v65? I just added a member to a tone set and it caused the program not to open. Removed the list from that tone set and it opened fine. Neither tones editor or twotonedetect will open.
Did you add the new member using the TonesEditor program or by manually editing the tones.cfg file? If the tones.cfg file isn't formatted properly it can cause the program to not start correctly. Using the TonesEditor should help ensure correct formatting.
Andy
aaknitt
I am unable to open the program- it hangs and then nothing comes up. I tried an earlier version, but nothing yet. Any suggestions?
Are there any errors in your log.txt file that might shed some light on the problem?
Andy
nick223
Ottawa Illinois
hmm..
I still cant figure this out ...
Waiting for Silence GRVFD 20:20:15 on 07/07/14
Done recording GRVFD 20:20:18 on 07/07/14
done writing WAV GRVFD 20:20:18 on 07/07/14
done converting to MP3 GRVFD 20:20:23 on 07/07/14
MP3 Email sent! GRVFD page received at 20:20:23 on 07/07/14 20:20:31 20:20:31 on 07/07/14
done converting to AMR GRVFD 20:20:36 on 07/07/14
Traceback (most recent call last):
File "TwoToneDetect65cPi.py", line 465, in mail
File "/usr/lib/python2.7/smtplib.py", line 613, in login
raise SMTPAuthenticationError(code, resp)
SMTPAuthenticationError: (534, '5.7.14 <https://accounts.google.com/ContinueSignIn?sarp=1&scc=1&plt=AKgnsbvwB\n5.7.14 3W1fJEH5bTwQNTeeyL3ITMju7w3kPGzDMo_ikN56q0NIoiW6C7EKHh-NYrhkTeA_jTFmf0\n5.7.14 wzA8YzLCpLmd4CB3jRXXRFsiCcv-9131G1pIogehkLJifxphvHwsE-z77x8-KtUxKEkb95\n5.7.14 CbTN69uRqvFbpmM-NhZypNMoJEZXbYZjHYGIffEDGWPR4UUt8miX9mI6gaEZz6fjjD0WSb\n5.7.14 VBBrOgA> Please log in via your web browser and then try again.\n5.7.14 Learn more at\n5.7.14 https://support.google.com/mail/bin/answer.py?answer=78754 p12sm692766igx.18 - gsmtp')
Email not sent on attempt 1trying again in five seconds for GRVFD Page Received at 20:20:36 on 07/07/14
SMTPAuthenticationError: (534, '5.7.14 <https://accounts.google.com/ContinueSignIn?sarp=1&scc=1&plt=AKgnsbuRJ\n5.7.14 lpcjlOlcIu_AYUNqRc2sygByUI9sqN06Pj3k7_JiBlVArmcvHktyVLYWUWSgvn_UTvHwWZ\n5.7.14 pwA0G46AWJ1Tv2opI4VPAw_p0tc9bZGViu2uvrNri8qePO7oD06c4gowEM7x9tIcD-tyFw\n5.7.14 V_r6xaa1q0cMqkQJFpcai0Xaxr2kG49
DC31
Massachusetts
Check, and possibly change your email login password.
nick223
Ottawa Illinois
Ttd email failure
Does anyone have more then 10 Verizon numbers on 1 alert that the email still sends? I recently just put a 3rd TTD in service and created a gmail and yahoo email account tried both emails and the email fails to send with more then 10 Verizon phones on one alert i guess it thinks im sending spam or something and rejects the email. Does anyone else have a solution ? Thanks to Jim for all the help in trouble shooting this issue and we are still racking our brains. Anyone have ideas or a work around?
Thanks,
Nick
emt603
Marceline, Missouri
OK, this may be a stupid question but my alert text takes like 2-3 minutes to go thru now. It used to come thru on my phone like 20-30 seconds after the page and now it is taking close to 3 minutes. any ideas what might be causing this? the rest of the guys say there's is taking longer too, it is a mix between AT&T, Sprint, Verizon, and Chariton Valley. It happens with all the carriers, not just a particular one.
tecker
Deshler, NE
Thanks,
Nick
I have a bunch of guys on my department all with Verizon and UScellular. Try selecting BCC in the settings for the program (i think it is in the config file not the tones file). I have heard the BCC can help on big groups.
kc7wsu
Utah
I thought that I would report back that twotonedetect runs on Ubuntu 12.04 without issue. I have it installed on a web server and It has run without issue for 28 days. If anyone is interested I will do a writeup.
I have been trying to get TwoToneDetect to work on Ubuntu 12.04 with no luck at all. I would love to see what you did.
Regards,
Chris Andrist
emt603
Marceline, Missouri
Ok, it seems that Gmail has went to hell just in the last few weeks for some reason. I used to get pages sent within 20 seconds now it is taking almost 8 minutes going thru Gmail. Is there anybody else that is experiencing this or anybody that has a work around?
Forts
Ontario, Canada
No issues on my setup. I send from a gmail account to a Google Groups account.. Which in turn sends out the email to 200 some odd subscribers.
ryolsen8
BEE07
Application Specific Password
Hi all,
So, for another Co I've got set-up, they aren't getting the pages sent. I believe I need to set-up the app specific password. As this was the case for another County. When I click on the instruction link, and click on the security link, I don't get any options anywhere to add a password, for a device..
Any suggestions?
nick223
Ottawa Illinois
Well I believe I just fixed my Verizon problem. I had to Email all the phone numbers from the text email first to secure them as a contact so they weren't considered spam.
tecker
Deshler, NE
Any suggestions?
You turned on 2 factor authentication? I dont think that the App specific passwords come up until you use 2 factor.
Somebody that has set this up more recently could correct me if I am off.
steve0622
Wichita Falls, TX
mms for sprint phones
I know some of you all have had issues with ttd and sprint mms going to XXX@pm.sprint.com. I am currently having the same issue. Most of the pages will not come to my phone anymore, but they always come through email. No issues with the latest version of ttd. I have been in contact with 2nd level tech support with sprint and was advised they are moving away from mms and going to email. The main server that housed the picture messaging service was decommissioned April 30th of this year. They are currently working on a work around for that. Most of my sprint recipents are still receiving the messages just fine, then some are very soprotic. I am also having an issue with some of my AT&T customers recvieving their pages but it says cannot download, message is corrupt. I have found out that AT&T takes the orginal message and resizes it to their standards. Has anyone found a solution to either of these to issues? I am using the latest version of ttd for 6 different departments, with 2 different computers and gmail as the email out. On a side not, everything had been working flawless until about 3 weeks ago...nothing has changes on local end.
emt603
Marceline, Missouri
Steve, i am having the exact same issues as you right now, Sprint is really speratic and sometimes it works and sometimes it doesnt. Please keep us updated if you figure out a solution!!
Mike
