TwoToneDetect New TwoToneDetect in the works - Python based
CDTbolt10033
Waterloo Region, ON
Any solutions or replacements?
Using TTD with Gmail to send alerts to the emails.
Google Less Secure Apps Access
"To help keep your account secure, starting May 30, 2022, Google will no longer support the use of third-party apps or devices which ask you to sign in to your Google Account using only your username and password."
Disregard the post above solution has been found for the issue.
MikeOrlando02
Had some spontaneous issues this week with missed page detection.
Code:
atone = 376.4
btone = 358.5
atonelength = 1
btonelength = 3
description = Crivitz Rescue
record_delay = 2
ignore_after = 0
In reviewing the log files, I see the audio was received and it is well within the 0.02 tone tolerance. Appears to have captured the appropriate tone length. What is puzzling is other agencies ARE being detected, meanwhile this agency missed all 10 tones yesterday and has not been working for a few days. Restarted everything, but I am struggling that it seemingly was only one agency.
Code:
376.4634146341463 22934 1650068175.8140676
376.4634146341463 22858 1650068175.9837632
376.4634146341463 23180 1650068176.184951
376.4634146341463 23432 1650068176.3637698
376.4634146341463 23663 1650068176.5487227
376.4634146341463 23273 1650068176.7340605
360.3292682926829 22211 1650068176.9184844
360.3292682926829 21830 1650068177.1033232
360.3292682926829 22296 1650068177.2880533
360.3292682926829 22556 1650068177.4823494
360.3292682926829 23274 1650068177.6667728
360.3292682926829 21736 1650068177.8516002
360.3292682926829 22201 1650068178.036313
360.3292682926829 22475 1650068178.2214136
360.3292682926829 22470 1650068178.4062562
360.3292682926829 22166 1650068178.5915933
360.3292682926829 22262 1650068178.7856839
360.3292682926829 23215 1650068178.9705133
360.3292682926829 22424 1650068179.1562192
360.3292682926829 21620 1650068179.342107
360.3292682926829 21861 1650068179.5265408
360.3292682926829 22818 1650068179.71217
I should also note the content of my knownhosts file were deleted again so my FTP uploads for all services stopped.
Any ideas?
ltginrage
Hello, I have TTD running on my new PC and going into my email. Currently, I'm trying to set up the pushbullet alerts instead of emails. I have the API Token in the Pushbullet API key spot & I've tried putting the channel name, the channel tag, the links to the channels to try to get it to send from TTD with no success. Does anyone know what is the correct thing to go in the Pushbullet channel name? I first assumed it was the channel name that went there but that don't work. so im really not sure what's wrong
MikeOrlando02
Code:
atone = 376.4
btone = 358.5
atonelength = 1
btonelength = 3
record_delay = 2
ignore_after = 0
Any ideas?
RESOLVED with replacing the knownhosts and restarting.
MikeOrlando02
I've accomplished this with Pushover instead, same concept and I don't entirely recall why I went away from Pushbullet. What I've done in the past is launched a post-command following the page that called a batch file and passed it the URL of the pager audio. The batch file would handle formatting the proper Pushover message and sent it using curl. I could try to walk you though what I remember if you want to PM me.
ltginrage
I'll give pushover a try in a little bit and let you know how it goes Thanks
Brigs164
Marquette
does ttd_helper work with TTD from iamrepsonding? i have TTD running on a pi right now and every thing works perfect but im getting into home automation and would love the MQTT support
DC31
Massachusetts
Yes
i use MQTT with TTD for automation of functions upon detection of tones. publish to a topic using the alert_command= option
CDTbolt10033
Waterloo Region, ON
Nope, there's a thing called app passwords in Gmail just use that and it will work fine however you do have to enable 2-factor authentication to use app passwords (I think).
Forts
Ontario, Canada
I've been fighting with this (here on another thread) and I've had no success thus far...
- turn on 2FA
- Generate app password
- Run app password thru Base64 encoder
- Plug encoded password into the config file
Every time I send I get an SMTP error saying an app specific password is required. Did you do any other steps along the way?
CDTbolt10033
Waterloo Region, ON
I just did steps 1 to 2 and then put my password in the config and it worked fine. Do you have email authentication ticked in the config? keep in mind I am using the latest TTD version (TwoToneDetect73l)
Forts
Ontario, Canada
Yes I have authentication checked and email security is set to STARTTLS. So you didn't Base64 encode your password for the config file?
Forts
Ontario, Canada
Ok thanks... I can't recall if I tried the password as is or not, I'll give that a twirl.
Forts
Ontario, Canada
Ok.... got it working now!
For anyone else looking to set this up... I did as posted above. Turned on 2FA, generated an app password. Cut/Paste that password into the TTD Settings Editor. Bingo, worked.
Previously I was pasting the password right into the config.txt file after Base64 encoding it. Clearly this isn't the way to go! Thanks for the tips CDTbolt10033!
smokeater474
Claremore, Ok
I have done this and still not working. What did you choose under select app? I chose other and generate and it gave me a 16 digit string of letters that I copy/paste into TTD.
smokeater474
Claremore, Ok
This is what is showing in the log:
SMTPServerDisconnected: Connection unexpectedly closed: timed out
Email not sent via smtp.gmail.com on port 465 using STARTTLS
