New UniTrunker release
Lakotawolf
Banned
I appreciate the help. So the source is the unit number right?
tactcom42
nc
YES.Have fun labeling all the ids.its the best part.listen then label.just hit enter after you label or it wont save it.you will have to do it again.
Lakotawolf
Banned
Thanks now the days of work start. lol
Mattsenft
Harrisburg, PA
I'm having the same problem as Airdorn. Running the old and new programs side by side with the same settings the new one does not show any data nor anything on the scope. Running the scope with provided with the older versions shows a perfect waveform and the older program is decoding at 100%. The computer I'm running it on has XP.
tactcom42
nc
What do you have your receiver set for?I have type is signal and sample rate is 96000 sample size is 16 and channel is mono.audio port is set to my sound card.per the help files.make sure you go to the run line and click on it and change to running from stopped.and hit enter.should work then.
Lakotawolf
Banned
Another dumb question this program is running but i dont see where it save on my computer anywhere. any suggestions?
tactcom42
nc
When you downloaded did you save it or just open it? download and hit save and then put it where you can find it and unzip it.
Lakotawolf
Banned
i did that its saved in my docs. but i see no icons to open anywhere
tactcom42
nc
mine went to docs then unitrunker folder open unitrunker folder and its in there.
Lakotawolf
Banned
Ok thats what mions doing. i wont lose all these units i`m tagging will i?
tactcom42
nc
I closed mine a couple of times my mistake and so far so good.it starts up and remembers all I put into it.just have to start the running again and away she goes.this program is sweet.
running win xp no service packs just old xp 800 mhz.
Lakotawolf
Banned
ok cool. i notice if i close i have to go and enter my GRE 500 again.
Installed and running with no problems, decoding MPT 1327 systems here in Australia without a problem - though seem to be unable to edit the band plan for the system, the line gets highlighted but unable to edit each field (tried all the usuals double clicking, right clicking, tab, enter and adding a new blank field without luck). Otherwise great work!!
Ocean County, NJ
Try highlighting the field, then press F2 on your keyboard.
K4OC
Clayton, NC
I appreciate the time it took to provide a free program for me to use. I cannot emphasize how appreciative I am. I am sure the person who wrote this program has a life and has a lot of other things to work on..so once again I appreciate your time and effort.
Sam Cederas
K4OC
Raleigh, N.C.
Jay911
Silent Key (April 15th, 2023)
Bragg Creek, Alberta
Haven't had a chance to actually run it with a radio input.. but I am finding some things regarding the programming and data manipulation.
There are no scroll bars on any of the windows (horizontal or vertical) under XP SP3 - is that intentional?
On the Changes page, when accepting or rejecting data brought in from a RR download, the two checkmarks visually do the same thing - only clearing a given line if it's selected. In regards to the program, the changes are only applied if the first one ('Accept change') is chosen. If the second one ('Accept all changes') is chosen, the changes are not saved to the system/database.
Ctrl+click works to select multiple entries. Shift+click (to select a range of entries) does not.
Mouse scroll wheels appear to not be supported.
Channels aren't being downloaded from the RRDB. I seem to recall that maybe this might be on purpose, though?
RRDB SID is not being shown on the system info page when a download happens. Should it be?
For what it's worth, if some tool decides to name some EDACS systems with text names like "ECOMM WARS EDACS901.SYS" so that he can store multiple EDACS systems in his Unitrunker folder, using the import feature in the new program (pointed at that directory) crashes it. Hard, to the desktop.
I'll add more when I run the program with actual input :) So far looks quite good, Rick!
mtindor
FMP24 PRO USER
Carroll Co OH / EN90LN
Ric,
i'll commend you on a job well done (and of course expected nothing less). However, I'm old school - I'd never prefer this interface over the old one :)
Is the lack of LTR logging on the PSR-500/600 only on this new release or is it not available on the previous release (I haven't tried it)? If so, can you refresh my memory as to what the problem is with LTR monitoring on a PSR-500/600?
- I don't see any scrollbars - I think that'll be essential.
I'm going to download your older versions [again] and archive them in a separate place because I never want them to go away rofl.
Mike
kevins669
New Orleans, LA
Rick: I get a crash every time when deselecting "Calls" in the history screen.
ALSO: Systems-->Select System-->Click on "Groups" tab
XP SP3
Perhaps others can test as well.
Let me know if you need details.
Thanks,
-- Kevin
