New user - over thinking it again :-)
So is the btech radio at 24 watts too much for the cigarette lighter?
Maybe. Depends on the efficiency of the radio.
As was said, RF wattage ≠ current consumption.
You would need to hook up the radio to a suitable power supply and check the DC current consumption with an ammeter. The manufacturer —might— have specifications on line, but take them with a grain of salt.
As cmdrwill said, the limiting factor is often the contacts in the cheap cigarette lighter plugs/sockets. They are not a good connector for long term use.
Other issue you'll often run into, tapping into existing wiring, even cigarette lighters, is a really good way to introduce interference into the radio. That will impact performance. There's a really good reason people are telling you to power the radio off the battery. Cutting corners never leads to good results.
cmdrwill
So Cali
Radio is probably not too efficient, so 24 watts and 50 percent would be 50 watts or more.
All....so in regards to the cigarette plug not being able to handle it. I looked up the specs the UV-25x2 pulls 7A peak, what if I used an "add a fuse" with a 10 amp fuse? wired it directly into my fuse panel of my car. I'd use a spare fuse that only had power when the car was on, but id also literally unplug the unit at its base station to avoid battery drainage just incase.
Thoughts?
Supply voltage 13.8V DC・}15%:
20A Peak UV-50X2 --- 7A Peak UV-25X2, UV-25X4
jaspence
Michigan
Check out this video on MURS.
Most CCC radios do not meet MURS FCC rules. I have 5 of the RT27V radios in the video and they are a great buy if you shop a little. A range of a mile or more is realistic unless you have thick forest or other obstacles.
I want more than a mile thou, I'd prefer 3 to 4, 5 even. If I can spend not much more for an in car radio vs a handheld that's justifiable IMO
After some research it appears my cigarette lighter is 20 amps.
Yes, it may be fused at 20 amps.
The cigarette lighter plug, the part that you'd push in, may also be rated at 20 amps. Problem is they are a poor spring contact and as they work loose, the connections get flakey, resistance goes up, voltage drops, all kinds of issues.
Also, like I said before, tapping into existing vehicle wiring is a good way to introduce noise into your radio.
It's your radio and your vehicle, do what ever you like. If you are asking for advice, don't do it as a long term solution. You'll just end up back here asking for advice on why there's so much interference on your radio, why the power is intermittent, etc.
There is a very good reason we are telling you to connect the power directly to the battery.
Thoughts?
It all goes back to tying into existing vehicle wiring. You'll get noise from other vehicle components.
Run power directly from the battery. There's a good reason why every reputable radio manufacturer tells you to do this in their install guides.
kb4mdz
Cary, NC
Cigarette lighter plug and socket is one of the worst ways to draw power. Period.
Avoid it.
