quietcropduster
- Joined
- Oct 2, 2017
- Messages
- 29
- Reaction score
- 0
The range of 2 Watt MURS radios *should* be better than 1.5 Watt FRS radios in a vehicle if you are using an external (mag mount) antenna. FRS radios cannot legally use an external antenna and the vehicle body blocks a good part of the signal. Whether a MURS radio with an external antenna will add enough range for your needs, I do not know.
The five MURS frequencies (with bandwidth) are:
151.820 MHz (11.25 kHz)
151.880 MHz (11.25 kHz)
151.940 MHz (11.25 kHz)
154.570 MHz (20.00 kHz)
154.600 MHz (20.00 kHz)
You do not need a license to use MURS for personal or business use but the radio itself does need to be FCC Part 95, sub-part J approved to be legal to use on the the MURS frequencies. The BaoFeng UV-5R radio you link to is not approved for MURS. The BTech MURS-V1 radio is. Here is more information about that radio:
https://baofengtech.com/murs-v1
MURS-V1 Review - Miklor
So the BaoFeng UV-5R if I buy that technically I'm breaking the law? I'm in LE and that's a no go for me. I'd just use my LE radio (digital) on a radio to radio signal only (no repeater) but I don't have 2 portables and I don't "own" them and wouldn't want anything to happen to it, thus buying my own pair.
what are your thoughts on these: https://www.amazon.com/s/ref=nb_sb_...-keywords=murs+radio&rh=n:172282,k:murs+radio
