New Windows 10 install
N9JIG
Sheriff
Moderator
Far NW Valley
So last month I bought an Intel NUC to use for radio purposes including a dozen or so instances of ProScan, ARC-xx, Pro96Com, AirNav Radarbox etc.
I reused a 1TB 2.5 inch SSD from my old computer, just plugged it in and Windows 10 found the hardware and everything worked. That SSD had started life with Windows 7 Pro, and I took the free upgrade to Windows 10 when it was offered. From there there were 2 different upgrades to the most recent v1703. The mechanical hard drive that this SSD replaced had started with Vista, later updated to Windows 7.
Last week I found a series of disk errors so I figured it was time to reformat and restore. I figured it might be better however to do a fresh install, so I can get rid of legacy crap from Vista and Windows 7.
I got a Windows 10 USB flash drive complete with the latest version (1703 "Creator"). I also bought a new M.2 SSD from Crucial (1TB $289 at Amazon) since my NUC has both an M.2 and 2.5 slots. I removed the 2.5 SSD and installed the M.2.
I then booted the NUC with the flash drive and the Windows installed prompted me thru the install process.
Now this is where I diverge. If you know me then you know I am a true Apple fanboy, 2 iMacs, a MBA, iPhones, iPads etc.). I not only drink the Apple kool-aid, I bathe in it. With this said, I have never had an easier OS installation than I did last night.
In less than 5 minutes Windows was installed, restarted and ready to go. All I had to do was type in the Product Key, confirm that I was in the USA and agree to the legalese.
Next is to install the hardware, that will be tonight's job. I have about 15 serial ports, a dozen sound cards and the BT mouse/KB. The last time I did this it was simple and easy so I don't expect any problems.
I am getting more and more happy with Windows 10, it is approaching the Mac in simplicity.
N2AL
Tennessee
Wow! I am also a drinker of the Apple Kool-Aid and I am shocked! Usually I curse Windows 10 because it does not function like I wish it would. Ha it doesn't work similar to a Mac I suppose.
Thanks for the information and I look forward to any advice you can give us Mac users. 73!
Rred
Here and there
Rich-
I was under the impression that you needed an Enterprise Edition (i.e. corporate) of Win10 in order to install it on a flash drive, and that even then, that's not the same as "installation media" so you couldn't install a new Win10 installation from it.
Exactly what did you use? Someone downloaded an ISO image of the Win10 installation disk to the flash drive?
N9JIG
Sheriff
Moderator
Far NW Valley
Rich-
Yes, I got the flash drive with the ISO on it and used my Product key.
N9JIG
Sheriff
Moderator
Far NW Valley
