nexedge96 TG 0:U 368 & close call Hits
whatWhy
I got this system Here. on 155.205
Sys: 0
Site: 0
Tg: 0:U 368
Ran 10
Anyway I program it I only get a hit on it if I program it as conventional.
Also before NXDN update that system would trigger Close Call hit. No more after update
Ubbe
Stockholm, Sweden
Check in Sentinel Edit Profile in the tab for Search/CloseCall where you have a button to check which frequencies you have locked out from search and CloseCall. Also check the Broadcast Screen tab so you don't have that frequency screened out.
Read your scanner first. If you have favorite lists, then copy them with new names to not mess up the ones you already have stored in Sentinel.
/Ubbe
mtindor
FMP24 PRO USER
Carroll Co OH / EN90LN
That is conventional NXDN, not trunked. I could be mistaken, but I think that Paul has mentioned that if you program a conventional NXDN frequency in as trunked you will not receive TG:0 transmissions.
The solution is to program it as a conventional NXDN frequency.
Mike
jonwienke
More Info Coming Soon!
VA
That is correct. More than once IIRC.
