Nifog utac
AuntEnvy
Central New York
Hello all ~ I noticed that Ucall 40 and 41 channels appear to be repeater frequencies. Does that mean they link nationwide? As in, somebody from Vermont would be able to talk to someone in New Mexico? Does anyone know exactly how these frequencies work or how/why/when they are used? Is the protocol for usage only for some kind of major federal disaster? Also, are there RID/UID's attached to the units?
Thanks for any and all input.
nd5y
Wichita Falls, TX
There is no nationwide link.
How the frequencies are used depends on your state and local area.
Some places have permanent fixed repeaters.
Some places use deployable temporary repeaters.
Some places use deployable temporary base stations operating simplex on the 453 MHz channels only.
Some places only have the frequencies programmed in their mobile and portable radios.
Some places patch the interoperability channels to trunked system talkgroups permanently or only when needed.
Here is an article about interoperability channel use from last week.
https://www.rrmediagroup.com/News/NewsDetails/NewsID/16564
AuntEnvy
Central New York
I see. I thought that would be the case. Thank you.
So the two repeaters in my area would only link around the state or are they even more localized to specific counties/cities etc.?
nd5y
Wichita Falls, TX
Most likely they are not linked to anything but I don't know where you are or what your local planning and resources are.
ecps92
Taxachusetts
Depends on where you are and what your State has implemented.
Examples:
Some states have these Repeaters on Stand-by and enabled them on a case-by-case request when needed, ie: Coordinated so they don't interfere with other possible uses.
Also some states have implemented Tri-Stacks
This is a cross banding capability to allow the V-U-8 cross-talk for an event.
Doubtful they are linked outside of the Site the Repeater is at, unless there is a need to patch them into a State/Regional TRS
Actual capabilities are controlled by a SWIC and/or Agency who can provide the LE/CJ/PS users with the information of where, who and how to enable these.
AuntEnvy
Central New York
Thanks guys. I've read some of that stuff before and it gets a little obfuscated, but I'll look again. ;)
62Truck
Ordinary Subscriber
Ø
My county has a repeater on U Call. I just tried calling Hawaii, the only reply I received was "shut up Carl"
KK4JUG
GA
I suspect most of the repeater pairs in the NIFOG actually get very little use. In the event that a large entity (a state, perhaps) would set up a dedicated network for interoperability, then it might be used. In our mobile command post, we have a repeater but it's programmed for use with our on-board handheld radios. With a computer and about 30 minutes, it could be reprogrammed, however. (I say that with a false sense of confidence because it hasn't be reprogrammed in probably 10 years and I'm not sure anyone can remember how to do it.)
AuntEnvy
Central New York
I'm sure they don't. That's why the other part of my post was inquiring about usage and protocol. I'll have to paw through that NIFOG DHS info and spend a little more time with it.
chief21
Western NC (Summer); Tampa Bay FL (Winter)
In my experience, most of these federal "interop" frequencies are primarily intended to be used in conjunction with radio caches (deployable repeaters and quantities of portables) that are transported to scenes of large-scale incidents when necessary.
That said, some local or regional jurisdictions may have their own "interop" channels for day-to-day use. This arrangement is probably most common for trunked radio systems since little additional infrastructure is required to implement.
ecps92
Taxachusetts
I've seen them used for Joint Local/Fed Surv Ops - so well worth keeping in the Radios
ChrisP
Portland, OR
Absolutely. I've been seeing a rash of surveillance on the I/O frequencies as of late...
- Chris
KC2zZe
Mid-Hudson Valley, NY
Misuse is rather common here too, Chris; on the western banks of the mid-Hudson River valley in New York. When one tries to get an understanding of why those, of all the channels available, get utilized, "nobody's using them," is the reply one gets back. When one tries to explain that interop channels shouldn't be used for such purposes (anyone from EMS, fire, or emergency management can eavesdrop on your conversations), the point doesn't get across. Just because nobody's "using" them doesn't mean nobody's listening.
