NJ Scanner Programming Files
cpuerror
Ontario, Canada
I'm having some problems uploading to my BCT15 using FreeScan. I'm actually trying to add to the file on the sticky. I'm trying to add a group under NJ Counties - N. I'm trying to create a group "essex" and importing the frequencies using the clipboard, copying from radioreference. I check everything and it seems to be in order, yet when i go to upload i get: "Critical error, invalid response code or insufficient resources, abort channel programming"
It's only happening to whatever groups or systems I add... everything else in the file uploads fine. Anyone have any ideas?
If you mean the file at the very first post, it has 3767 channels in it. The 15 holds 2500. So you may be well out of memory. The best way to check is to go to the front panel and Menu * Settings * See Scanner Info * % Memory Used.
johnyvico
uploading
id like to upload my philly/snj file , but i have no cluse how to do it , if someone can walk me threw it ill put it on so u can critic or enjoy . thanks
fireman_dude
Jersey Shore
Johnyvico,
First off you have to locate the data files on your computer. Will end in USD as a general rule for BCT 15 and SS8 for BCT 8. Once you've located where they are on your pc, reply to this thread and use "manage attachments".
Click on browse and go to location where data files are stored. Select file and click Upload. You can do up to 5 files in one message. Since the only format for scanners permitted to be uploaded is USD, any other type you will have to zip. (or you might want to try renaming the file with the .zip extension and then put in your message for people to rename back to the original extension). Always put in your reply what scanner files are for. Good Luck.
jvdet
north jersey
I too see a problem - slight - that files are here - you cant tell when they are updated
On the Yahoo groups as files are uploaded - updated it can send out an email notice and if not list the files by the date uploaded,
i dont see much of that here
jjudson
Northwestern North Carolina
Here's one for South Jersey - Gloucester County Fire and PD - including the newly modified zone coverage - along with State Police and Philadelphia Media. Everything is categorized and grouped with both system quick keys and group quick keys for segregating systems and groups during joint operations. It is a Freescan file originally built for the BCD396XT. I chose Freescan as more people would have access to that than some of the paid programs I use.
  • BCD396XT South Jersey - Gloucester.zip
bezking
On the Road
Folks,
I have removed several off topic posts. Please keep discussion in this thread to ACTUAL PROGRAMMING FILES. Please ask questions in the appropriate forum.
Thanks!
johnyvico
my file
damn i trying to upload my file cant get it to work grrrrrrrrr
rwscull
Southern NJ & Misc Files
Enclosed are Camden, Cape May, Cumberland, Gloucester, & Salem Counties.
Also NJSP Troop A, B, C, Air, Marine & Media files.
They are for the ARC246 Program.
Bob
W2ROK
  • ScannerFiles.zip
JimBobTerp
Easton,PA
Hi
I have a question I am looking for help with more I am able to hear North Simulcast of NJSP I was wondering if I programed all these talkgroups & IDs from Group A and Group C and the rest of these talk groups and ID's from here New Jersey State Police Trunking System, Statewide, New Jersey - Scanner Frequencies and from here http://wc2em.net:8080/scanner/NJSP.pdf and a few from the NJSP Spreadsheet under group B. are can someone just copy me a good list of every ID and talk groups for every thing with PD dispatch and ect and fire or what every the other ids and talkgroups and then i will program all these in and still leave it on ID Search and let it pick up new ones. I have Uniden BCD966XT thanks so much.
PS. I am also using FreeScan software to program my scanner
Skypilot007
Medford, NJ
Hi
Here is my NJSP system file for free scan.
  • NewJerseyTRS.zip
georgezinser
Help please
im trying to program my cdm1550 for ocean county truked system. police north fire marshal and fire zones. in my cps all can do is enter in Rx low id and rx hi id. i can't enter in the hex like on the website. can any one help please???
W2SJW
Senior Member
Northwest NJ
Wirelessly posted (BlackBerry8350i/4.6.1.313 Profile/MIDP-2.0 Configuration/CLDC-1.1 VendorID/103)
First, this is not the proper forum for programming questions about commercial radios.
Second, that radio will not do Motorola Type-II trunking.
Third, If you have any reason to be on the Ocean County TRS, the appropriate people would have provided you with a legitimate radio.
Stick with a scanner...
JimBobTerp
Easton,PA
Hi
I know I have asked this before and people are giving me their files to download and it hard to get the files to open up in my FreeScan program. Now What I am going to do is program the ID # and tags on my own. I have seen some other ones pop up from Troop C. I know I can hear the Toll Bridge from my house. But can u look at this list New Jersey State Police Trunking System, Statewide, New Jersey - Scanner Frequencies and tell me what other good ones I should program in. Also when I do the Toll Bridge I know they are on Digital P25 should I change the Audio type to Digital On or leave it at ALL. I hope someone will give me ideas and some help. I know I am been a pain but I am trying to get my BCD996XT full of stuff. thanks again
08GMC4X4
BCD396XT Tri-State
This is my BCD396XT file. All of Jersey and some other States.
BruceB
bruceb
Bc 246t
Does anyone have a profile fore Beern county they would like to sharre? I'm using Butel sotware, and a BC246T
Bruce
