NJ Scanner Programming Files
jvdet
north jersey
Every body has the freq
If you can find this site and post you can find all you need in the Data Base
even a caveman can do it
The Parkway State Police units are on the state trunk system
W2SJW
Senior Member
Northwest NJ
Guys,
I successfully managed to sell my 396XT last weekend, so I will only be continuing to support my FreeScan file through the end of the month.
Many thanks to all those that have downloaded the file over all these years!
jvdet
north jersey
Thanks for your efforts on posting your file; it became a template for me & i hope for others using FS;
with the new Uniden and even the GRE radios many people are making corrections and making custom files for their areas ; i hope people will post those files so when & if the rest of us move up to phase 2 and the like we can have a working template to work from
W2SJW
Senior Member
Northwest NJ
I very much plan on sharing my HPE files from Sentinel.
If I understand how the memory structure is working from what I knew from my HP-1, there will be separate favorite lists for:
  • North Jersey
  • South Jersey
  • Metro NYC
  • Eastern PA
  • Delaware
  • Maryland & DC
It will basically mimic what I had in my 396XT (I travel quite a lot for work).
jvdet
north jersey
About those files
while i dont have a HP i would like to see files; how its done; what it looks like ;
However I UNZIP the files and the folders were empty
nosoup4u
High Bridge, NJ
Thanks for pointing that out. I have to figure out what is going on.
Sent from my SM-N9005 using Tapatalk
ScanXO
formally East Jersey part time south of the Border
while I dont have the new uniden - Yet - I have been playing around with SENTINEL - building a Favorites lists - how do you import your FL from another user - the file look like fl000001. xx but how do you give the list a name under the files section ? how do I use/import your files customized for Warren County, I cant get to import onto my FL;
As people build FL's and want to share - how do u share /import?
W2SJW
Senior Member
Northwest NJ
You don't actually mess with the FL as it sits on your PC. You go on the main screen in Sentinel & go into the 'File' menu. There you will see the import & export choices. When exporting, it will ask you what FL to export, and then how much of it. Then it will save the file as an .hpe file with whatever name you choose.
When importing the .hpe files, you will be asked to choose an existing FL to import to, or to create a new one. You do not have the same option as when exporting to only do a partial import. I hope they fix that in the future...
W2SJW
Senior Member
Northwest NJ
Just to make sure, you are using the x36 Sentinel, not the HP-1 version, right?
I tested it by exporting one of my FL's & then re-importing it to a new FL called 'TEST'. It worked flawlessly...
Sent from my Galaxy S4 using Tapatalk 4
ScanXO
Yes - using x36; so i downloaded your zip again and they are all hpe now;
BUT I went and up graded Ver 1.01.07 to 1.02.01 and lost my FL's ! the newer version x36 would not load them ? its wants a new FL but my old FL are missing
I find the software easy to customize if only i can stop loseing the work i have done - except !! I exported only a small fraction of my files to the files section so under 1.02.01 i imported those back but hours of the rest of the original 2 FL's are gone
jvdet
north jersey
Once you get to using it - it gets easyer ? with time; do save save save your work before closing - exiting out; BUT since the some radios have been recalled we are not yet commited to getting the 436
MADMAG486
NEW JERSEY
WOODBRIDGE TOWNSHIP
does anyone have any info on woodbridge pd it appears that my 436 was receiving them fine then after firmware update lost them check all info on scanner seems to be right but no transmissions.
philmann
New Egypt, NJ
Dumb question
just started with the radio hobby thing, I have a radio shack PRO-197 (which is pretty complicated for this knucklehead), how do i use the attached files, can't seem to view them ...thanks Phil
Hamop54
Fairfield NJ Police Frequency Query
I looked up the Fairfield NJ Police in Essex County and found 853.3625 listed as F1. I've listened there and cannot hear any signals.
Does anyone have any information: Are they digital? Are they someplace else?
Any information would be appreciated.
Thanks es 73
Dan
W2SJW
Senior Member
Northwest NJ
They are full - time on the NJICS trunk system. They are FDMA, so the existing batch of digital scanners can receive them.
Sent from my SPH-L720 using Tapatalk
AC2OY
Belleville,New Jersey
Dan what type of scanner you using? Like Scoot said there on the Interop system talk group 4xxx I a,ways get hits on them loud and clear!
Hamop54
Fairfield Police
Michael,
I'm using my Kenwood TH-F6. Guess I won't be hearing them on that radio.
I figured they were someplace else.
Anyway thanks for getting back.
Very 73,
Dan WA2CLP
P.S. You can find me sometimes on 146.955 Pl 141.3
