No audio with SDR# and VB-Audio Virtual Cable
P25_LA
Los Angeles, California
I'm driving myself crazy trying to figure this out. I had VB Cable and SDR# working fine but now all of the sudden if I go into Sound Control Panel (Win10 64bit) and select "Listen to this device" I can't hear anything. I have the output set to Default device, and if I go in to SDR# and set my Output to headphones I can hear audio fine from an active frequency. But, if I select VB-Audio Cable as output I can't hear anything and the levels register 0 when I look in the Windows 'Recording' tab for the control panel. This was working fine before but all of the sudden it quit.
I tried uninstalling/reinstalling VB-Cable and rebooting but the same behavior is observed. I know it's something simple, what am I missing? It's a big deal because for months I've been feeding the output from VB-cable to DSD+ to decode P25 and it's been working fine.
BM82557
Berkeley Co WV
Check your audio input devices and audio output devices numbers in Windows, from time to time mine have changed in Windows. I don't know what happens to cause it though.
S
simpilo
Guest
I don't know how Windows 10 displays it but make sure VB-Cable is set for default recording device matching my Windows 7 images.
They can't be that different. Playback default must always be your system sound speaker output.
spongella
W. NJ
I experience the same thing and use SDR# and VB cable. When I pipe the audio from SDR# via VB cable to MultiPSK software, the audio is fed to the sound card and I hear no audio anymore. It's a bit of a bother, but as long as I can see that the audio is being fed to the software (MultiPSK has a main window for this) that is fine.
spongella
W. NJ
Yep, sometimes I've had to just run Zadig again just to get SDR# to recognize the dongle again. I wonder if when Windows updates occur this has something to do with it. Glad you got back up and running.
