no Mp3 with twotone
pj226
Port Dover
I need a little help. I have twotone up and running sort of.. It will send the mp3 to an emai address and the person can download it and hear it. But when it sends it to there phone they are only getting a text saying Page recived, and what ever I put in the email body.. The phones that do recive the mp3 by text and can hear it are ones from koodo. So I belive the program is installed properly, Im just stuck on how to get the mp3's to the other phones. Im in Canada, the gateways Im using are Rogers number@sms.rogers.com Bell number@txt.bellmobility.ca Virgin number@vmobile.ca Telus number@mms.telus.com Are these Right. if so what am I missing... Thank you
pj226
Port Dover
if anyone can understand this.. does any of it have to do with why I can not get the mp3 deliverd to a cell phone?? [wav @ 01AF8540] parser not found for codec pcm_s16le, packets or times may be i
nvalid.
[wav @ 01AF8540] max_analyze_duration 5000000 reached at 5015510
Input #0, wav, from './audio/Station_2_2015-01-1112_08_49_294000.wav':
Duration: 00:00:30.65, bitrate: 176 kb/s
Stream #0.0: Audio: pcm_s16le ([1][0][0][0] / 0x0001), 11025 Hz, 1 channels,
s16, 176 kb/s
[mp3 @ 038595C0] Unsupported sample rate.
Output #0, mp3, to './audio/Station_2_2015-01-1112_08_49_294000.mp3':
Metadata:
TSSE : Lavf53.12.0
Stream #0.0: Audio: mp3, 11025 Hz, 1 channels, s16, 32 kb/s
Stream mapping:
Stream #0.0 -> #0.0 (pcm_s16le -> libmp3lame)
Press [q] to stop, [?] for help
size= 120kB time=00:00:30.77 bitrate= 32.0kbits/s
video:0kB audio:120kB global headers:0kB muxing overhead 0.026810%
done converting to MP3 Station 2 12:08:49 on 01/11/15
MP3 Email sent! Station 2 page received at 12:08:49 on 01/11/15 12:08:54 on 01/1
1/15
'c:\test2.bat' is not recognized as an internal or external command,
operable program or batch file.
DC31
Massachusetts
nvalid.
s16, 176 kb/s
Metadata:
TSSE : Lavf53.12.0
Stream mapping:
1/15
TTD is doing its thing properly as indicated by the "MP3 email sent!" entry. The problem lies in the address that you are using for the cell phones. Any address that has sms or txt in it will not work. You need to be using the mms gateway.
An email sent to a sms or txt address will be received as a simple text without the audio attachment.
Sorry, I am not in Canada, so I am not much help in sorting out the Canadian cell mms addresses.
