No Squelch tone.
TreeTall
Granby
Squelch is working so the numbers changing as knob is adjusted but at no setting is there no squelch tone.
bob550
Albany County, NY
What scanner are you using? If you're scanning digital only, the squelch won't open even at the lowest setting. If your scanning analog frequencies, then it should open if adjusted low enough, and if CTCSS is not in use.
JoeBearcat
Inactive member
Uniden Representative
Trunked systems will also not open the squelch. Try it on an unused NOAA frequency. Usually, a squelch setting of 2 is enough to close squelch but still be sensitive enough.
Ubbe
Stockholm, Sweden
Do you get beep tones from the speaker when pushing buttons, so you'll know that the audio are still working?
/Ubbe
