The Par filters are what is known as "notch" filters, they filter very sharply at the specified frequency, with fast recovery to either side. I thought Dale had the charts for the filter on his site, but I don't see them. Imagine a very steep valley centered on the frequency, this is the "notch". To either side the signal rises quickly back to normal. Down in the lowband OHP area, there should be little to no effect. BTW, I recommend that you ask for a filter with female BNC connectors on both sides. After using my pager filter on my mobile scanner, hanging on the back of the radio for 3-4 years, the pin in the center of the male BNC broke. Dale made the replacement filter for me with female BNCs, and I connected it to the scanner with a short BNC jumper cable to eliminate mechanical stress. Works like a champ! I was using the 158-HT filter, and the effect on the local/area fire frequency of 154.130 (state fire) was negligible, certainly much preferable to the way the pager transmitter was wipping out this frequency before I bought the filter.
Use the email link on the
website to specify your needs, and he'll shoot you back a price and delivery time. I have no connection except as a very satisfied customer. I can't recommend them highly enough. Oh, BTW, with the filter he will supply a graph showing the actual effect of the filter. You'll be able too see just where the filter kicks in and where it returns the signal to normal.
Mark S.
