Node not populating into playlist
n1riw
Provincetown, MA
I have a playlist set up for Polk/Desoto/Hardee county. Specificially for Desoto County FD and Aeromed. I see Node 1226 is operating but the calls are not populating into my playlist. I noticed then in the node page but when I select "Systemwide Live Calls" there is nothing there which I believe to be part of the problem.
Any help in figuring this out is greatly appreciated.
Tim
n1riw
Provincetown, MA
I have a playlist setup for Sarasota FD County which has stopped working. I see the node on the list with calls on it so cant figure out if I have something wrong or there is a configuration issue on their end..
Can anyone explain why this is happening? I'm having similar problems with a Polk County playlist and had no response to my question.
Thank you
Tim
Can anyone explain why this is happening? I had a similar problem with a Polk County playlist and had no response to my question.
Thank you
Tim
I do not see a public playlist for it, so I'm guessing it is private, are you logged in with the correct account to access your private playlist? If it is public, please send a link and we will check it.
n1riw
Provincetown, MA
My playlist url is:
The Manatee/Sarasota node is:
I did notice on the node if I select System Wide Calls it is blank which is not normal.
The Polk County node is :
Hope that helps
mtindor
FMP24 PRO USER
Carroll Co OH / EN90LN
My playlist url is:
Hope that helps
If you want to create a public playlist, you must run it by @blantonl to ensure it meets TOS and is useful.
Others cannot see your private playlists -- so those links you provided to your private playlists are no good for others to view if you post them.
And if you create a playlist with talkgroups that are only available from one node and that one node is down, then you won't have any activity on your playlist. Your playlist is just a playlist, one that happens to make use of broadcastify feeds that others provide. If a node that typically provides those talkgroups is down, you have nothing. If the node provider removed those talkgroups and it was the only node that provided those talkgroups, you have nothing.
My playlist url is:
Hope that helps
You are trying to listen to old NODES, which it says you can't do, which is why when you select System Wide Calls it is blank.
blantonl
Founder and CEO
Dallas, TX
The manatee node has been down for over 24 hours, that’s why there are no calls in your playlist.
when it says “ No Calls Seen in the Past 10 Minutes” it means what it says….
blantonl
Founder and CEO
Dallas, TX
Node 1226 is not operating, look at the last date and times on the calls. It’s been down for over 24 hours
