I recently bought a 1080 and have done all the software,firemware,library updates. My screen LCD keeps turning off way to quickly, which is driving me nuts. As I can't see anything after the backlight goes out. I went back to defaults and was the same. I've changed the proper settings as far as I can tell from reading the manual and other references. I want it to stay lit for 7-8 secs once I touch a key or a freq breaks sql while scanning. I changed the backlight setting for batt to 'key' and changing the delay from '5' (default) to 7 & then 9. This doesn't seem to make any difference. I do go to 'save settings' before exiting this menu. I also turned on the 'lit when unmuted', which I assume the backlight comes on when a channel is found.
What is the difference between 'Norm' and 'Key'? Probably the best assistance anyone could give me is what are the settings you use when running only on batts and when hooked to power.
I can't wait until I get past the high learning curve of all these settings and programming!
Thanks,
J.C.
Thanks,
J.C.
