North Wildwood PD
TerryPavlick
Wallingford PA Villas NJ
Done. As suspected, they moved to the UHF repeaters in DMR mode. If anyone can confirm the TGID and Time Slots in use, please submit that so it can be added to the listings.
Also, keep in mind that DMR is TDMA, so they may have multiple talkgroups and time slot usage on each frequency.
Check submission for North Wildwood.
katt02
Katt
would anyone know (or be able to find out) if they have RAS employed on the repeaters?
philacop
Clifton Hgts PA
Caught a second or two here up in Delco!
Definitely color code 9 TG 101 slot 1 with radio ID 507100.
Hopefully later tonight May get better signal and listen more!
mshumeyk
Southern New Jersey Shore
Avalon and Stone Harbor just left their DMR systems for the P25 NJICS. Perhaps North Wildwood got a good deal on purchasing their DMR radio equipment.
GTR8000
NY/NJ Database Guy
BEE00
Enter the repeater frequency, then select Audio Type: Digital Only, then set the DMR Color Code to 9.
NParkNJ
On the Road
Northern NJ
something to keep in mind for those who don't know, assuming they are using RAS(restricted access to system-at repeater) no radio without the proper RAS code will be able to listen in. You will need a scanner, or another means to listen in.
mshumeyk
Reminiscing about a week spent in Stone Harbor when I was a kid way back in 1970. I was able to listen to all of the Cape May shore towns on 156.21 using a tunable Radio Shack Patrolman VHF high and low band tunable monitor. Now to hear all three Wildwoods simultaneously on a single receiver you pretty much need an SDS100 with the DMR option. Fortunately I have one along with a 436 and 325PD also with DMR. Guess I may as well send the G3 to Unication for the $25 DMR upgrade.
