northumberland county pa
Firemandakota87
Sunbury PA
why is the other p25 sites and frequencies for p25 not available in Northumberland county it would make for the unicaton pagers work a lot better
Firemandakota87
Sunbury PA
Whiskey3JMC
Don't feed the squirrels
Simulcastylvania, TE
Can you post the FCC license(s) for the other site towers? RR relies on user data to stay up to date so if you believe a site or more is missing, feel free to submit the info once you've verified it
Firemandakota87
Sunbury PA
thats the only problem i dont know the other sites/ towers and frequinces for them i jsut know from a friend that there is more towers/site and frequincies i just don't know how to find them and get them
BigLebowski
Piedmont NC
It's a simulcast system. All the sites have the same frequencies at every site.
BigLebowski
Piedmont NC
Gotcha well there is supposed to be a few more towers in the area than just the one listed
It is is SIMULCAST system. I realize that you may not know what that is.... it is one site that consists of multiple towers that all have the same frequencies and transmit at the same time. There are no other "towers" to speak of.
Firemandakota87
Sunbury PA
Alright just was checking cause a friend said there's one up here in turbotville and then a few more out side sunbury as well
HM1529
Pennsylvania DB Admin
West of the Atlantic Ocean
If you're talking about standalone sites not part of the simulcast system, they wouldn't be listed because nobody has ever submitted information about any site repeasters. Only information about the simulcast cell was submitted. So, either you are referencing towers part of that simulcast cell or there are unaccounted for site repeaters. If the latter, then somebody needs to do a little searching to get the control channel info.
Firemandakota87
Sunbury PA
How would I be able to find that info out
HM1529
Somebody would need to search in the Turbotville and Sunbury areas for control channels other than the ones listed for the system.
If present, they would likely be in the 156.2475 - 162.0125 range. Keep in mind there are sites on the state system that use frequencies in the same range, so those would have to be cross referenced to eliminate them while searching.
Firemandakota87
Sunbury PA
alright what for electronics do i need for that
SlipNutz15
Wacker
Central PA
There are no separate sites. It's just a single simulcast system.
The only Conventional channel I've seen from an on-system radio is 155.1000 (Rx CSQ) / 155.1000 (Tx 103.5) and it's not even loaded in any of the banks for use. The channel name is called INTEROP1. *shrugs*
