qlajlu
Silent Key
I am trying to become acquainted with this new object scanning platform used in the current GRE PSR 600. This is totally new to me having used nothing but Uniden my entire scanning life. AND I'M STUCK!
I'm using WIN500 software to help me populate the scanner with the huge systems in my area and I have had it running just fine - TWICE! Each time I have hit a snag and I'm sure there is a simple "fix" but I cannot find it. Maybe I'm using the software wrong. I dunno.
Okay, the first time I downloaded a system from the RR Database with no hiccups, but I got the wrong text for the alpha tags because I was thinking "default" was good. Silly me. I had to down load the entire system again and when I did I got the following: Nothing enabled! ...and the number 1 flashing slowly with two lines of dots on the scanner's display. No matter what I did, I could not make it scan, however, if I went into manual mode, I could scroll the 01 scan list, so I knew the scanner was populated, but I could not make it scan.
I ended up deleting the system I had in the scanner and downloading the same system again from the RR Database, only this time I made the right choices and got the alpha tags correctly, uploaded to the scanner AND the scanner took right off like a turpentined cat.
TODAY, (You'd think I could leave well enough alone wouldn't you, but, oh, no, not me.) I wanted to add a few of the objects to the Favorites List, so I unlimbered the WIN500 program, found the 01 Scan List, scrolled to the TGs I wanted to put into the Favorites, uploaded to the scanner. Guess what I got! Yep, you guessed it! "Nothing enabled!" a slowly flashing 1, and two lines of dots.
I can still manually scroll through the 01 Scan List and see the "objects" in the scanner, but it will not scan. So my questions:
Oh, I need to add that I can scan the Favorites List. How do I enable the other one (hopefully using the software)?
1. How do I ENABLE this thing without downloading the whole bloody (353 TGS + the CCs) system again from the RR Database?
2. How do I use the WIN500 software to make these kinds of changes (add to Favorites List) without going through this whole thing again?
