SDS100/SDS200: Nothing Happening
ggermain
I received my SDS100 today and updated the Firmware and Database. I used Sentinal Software to build my Favorites list, and uploaded it to the scanner. I'm not getting anything on the scanner. I am in St. Clair County Illinois, and I am trying to get St. Clair County Police (and some of the municipal PDs in the area), Local Fire and Local EMS. I know that lot of it is on Starcom21 (both P1 and P2), but I cannot get anything. Help?
Whiskey3JMC
_/|\_Surf's up, Happy DX!
Simulcastylvania, TE
How many bars of signal are you getting? DATA link? Is the favorites list set to monitor? All applicable service types turned on for the talkgroups you want to hear? Did you set quick keys & are they turned on? Be sure to only monitor the closest site to you, the more sites you scan at a time you'll be bound to miss traffic
trentbob
Silent Key W3BUX
Bucks County, PA
One thing when you unbox the radio is that all service types are not enabled, can never figure out why it is that way by default but, simply go in and enable all Service Groups and let us know if that helps.
hiegtx
Dallas, TX
Besides the service types already mentioned, did you update your location in Sentinel before writing your list to the scanner? If you did not, and the list you created is set to use location control, you will not hear any radio calls. Edit your Favorites list in the scanner, via the menu. If location control is enabled, turn it off & see if you now hear radio calls.
tvengr
Well Known Member
Baltimore County, MD
The most common problems are the service types are not enabled and Download and Monitor are not both set to On for the favorites list in the profile editor when you write the favorites list to the scanner. Download sends the favorites list to the scanner. Monitor enables it to scan. Please attach your favorites list file so that we can take a look at it. Go to the File tab in Sentinel and click on Export to hpe file (Favorites List}. You will need to zip the exported file to be able to attach it. Click to Attach files and open the zipped file.
sonm10
Central MN Monitor
Sauk Centre, Minnesota
This may sound really dumb.... but do you have an antenna connected? Also, the stock telescopic antenna may or may not be sufficient indoors. It may be possible an outdoor antenna is needed. Again, as whiskey asked, do you see any signal bars?
Whiskey3JMC
Well if they enabled every service type right out of the box then more threads would get started on this forum from people complaining that they entered their zip code (as opposed to programming FLs) and are only getting taxi cab or school bus chatter, which most folks aren't slightly interested in. It does make sense to me to only enable what is most commonly monitored: EMS Dispatch, Fire Dispatch, Law Dispatch, Custom 1, and Multi-Dispatch as Uniden does and switch on anything else as needed
Ubbe
Stockholm, Sweden
Or if you go into a restaurant and and you sit down and they start to bring in all sorts of food to your table.
- What are you doing?
- Oh, you didn't want everything on the menu?
-No, I want to start with the complementary bread and water and then only add the food I select myself from the menu.
/Ubbe
dave3825
Suffolk County NY
Oh man, if they do that in Sweden, I am on the next plane !!!
Guess Uniden can't make everyone happy.
trentbob
Silent Key W3BUX
Bucks County, PA
I miss a good smorgasbord, some of the vital transmissions in my area are not necessarily mislabeled but labeled in a peculiar way.
I would also want to start with emergency Ops, EMS talk, EMS Tac, fire tac, fire talk, Hospital, interop, law tac, law talk, multi tac... yeah just give me the whole menu, I can always turn the oil delivery trucks off easily enough😀.
tvengr
Well Known Member
Since it is such a common problem with new users having service types disabled, it would make more sense to have them all enabled when Sentinel is first installed and then eliminate the ones you do not want.
donc13
Grand Junction, CO
Actually, if you RTFM then you know what service types are turned on out of the box.
And yes, I know, reading instructions is so yesterday now.
phask
zanesville
Need to see your FL file and a screenshot of profile scan selection screen.
Edit-export to hpe --- then rename the file to xxxx.txt and post (can't post a hpe file.
