Nothing Scans Now.
Searcy, AR
I lost my V-Scan file on my ws1040 nothing worked. I loaded a new Scanlist 01 with my county information. It loaded but does not scan. Any suggestion?
tvengr
Well Known Member
Baltimore County, MD
Is Scan List 1 enabled? Press the SCAN button. What software are you using? Please attach your programming file so we can take a look at it. You will need to zip the file to be able to attach it. Click on Attach files and open the zipped file.
Searcy, AR
Scan List 1 is enabled, all other scan lists are disabled and flashing on and off. I am using ARC500.
Searcy, AR
I use ARC500 also. If you attach your file, I can check it for programming errors.
I sent you a file. I have it working now. Thank you. I loaded my son- in-laws file from his scanner. My whistler 1040 is now working.
tvengr
Well Known Member
Glad to hear it's working. I don't see the file. Did you download your son-in-law's file into ARC500 or did you clone the scanners?
Searcy, AR
Yes I loaded his v-scanner file from his radio shack scanner. It works fine on my whistler. Yes I used ARC500 to load it.
