NW Central programming help 396T & 15X
Portage Park, Chicago
using Freescan I can't get NWCD to work. As a SYS type I chose mot type II/P25 & site type I chose mot custom/reband. On the 15X it loaded fine and when you hit the hold key the site id is displayed but when scanning I get nothing. On the 396T it kept telling me "failed adding group fire. scanner may be out of memory" the other error messages I get are: setting agc,global p25 wait time & scanner max channel or max TGID limit reached. I know i'm not exceeding channel or tgid limits, i enterd 19 for NWCD and 4 for another SYS . Icleared the memory of the 396T and tried reloading NWCD alone and STILL got all of the above error messages. The firmware was just updated. any help is appreciated.
I solved the 396T problem - just needed a firmware update. the Uniden firmware update site is garbage. The directions are very confusing and after about three hours I was ready to through my coputer through the wall!
N9JIG
Sheriff
Moderator
Far NW Valley
Good job with the 396.
The BCT15X will not work with most of the NWCD talkgroups (on the AH-BG-MP-PL-PH system anyway), as they are digital, the 15 isn't. There are a few analog talkgroups on that system that will work on the 15 used by some of the Local Government services. The Streamwood-Hoffman Estates and Schaumburg systems are still analog and will work fine with the 15.
