NX-5000 Series, Q&A, Info, and details
Cbr600rr2
So with the DMR channel, it is on the correct Color Code and GID? If there are multiple users on a FB6 (community repeater) or different TG in use on a single repeater, all 3 DMR items have to match, CC, SLOT, GID.
The other would be your scan window settings, if its too tight this can happen also.
I have no idea what any of this means. Is there away you can call me?
Cbr600rr2
Or can I email you the code plug of the radio and you can see what’s going on and possibly fix it. More than happy to compensate you
03msc
RF is RF
The Natural State
You don't know what Color Code, Group ID, and slot mean? You would pretty much have to know those to have programmed DMR...
  • Like
Reactions: RRR
Cbr600rr2
I didn’t program it. A company did and they screwed up. And it went back 3 times they can’t figure it out. So I bought the software and figure I’d try and I can’t. I can program Motorola no problem but kenwood no idea. So I’m looking for help
03msc
RF is RF
The Natural State
OK, gotcha.
The Color Code is kind of like CTCSS on analog. The timeslot...on DMR there are two timeslots that can be used, 1 or 2. And then of course the talkgroup ID that you want to talk on. So, you have to know the CC, TS, and TG (GID) for a channel. That's what Evans was talking about, making sure they were all correct.
Cbr600rr2
OK, gotcha.
Well it also seems like you know what your talking about. Can I email you the code plug maybe you can figure it out??
03msc
RF is RF
The Natural State
Honestly I don't know if I'm that good lol I just know those things have to be right. Maybe post a screenshot of your channel screen in the software and let's crowdsource it here and see if someone notices something that's off.
Cbr600rr2
Hey guys I figured it out and got it to work it was a stupid setting issue. But now I have a different problem. When in priority scan. The analog channel that is a receive channel cut outs out and there’s a knocking noise rather than the transmission but when it’s not in scan mode it works fine. Anybody have any idea?
Cbr600rr2
Could it be because is the site roaming??
03msc
RF is RF
The Natural State
Like it's checking the priority channel? If you're in priority scan and it stops on a channel other than the priority channel, it will 'look back' to the priority channel at the regular interval you have set to check for traffic on the priority channel. I don't recall the default off hand but it's like every second or maybe faster. If you don't want it to do this, don't use priority scan but rather just regular scan.
Cbr600rr2
Ok I tried setting up the regular scan but if someone transmits on the selected channel it doesn’t revert back. Any idea how to make this happen? And also do I need to take priority scan off?
Cbr600rr2
Did you build the scan list?
My NX-5200 and NX-5300 Scan NXDN DMR and CONVENTIONAL all in the same scan list.
I did. When I put it on list I can’t even turn on the scan. And when I go single it will not revert back to the selected channel can I email you my code plug??
ramal121
Lots and lots of watts
Calif Whine Country
If you want priority scan then enable it. Adjust the Lookback Time A to something that pleases you between rapid audio holes and missing the first word on the priority channel. I like about 1 sec. No way to completely eliminate the drop outs.
Cbr600rr2
The problem isn’t losing a word or whatever. I have A set to 0.50 and B is set 2.00
The problem I’m having is when priority scan is on the transmission of the analog channels gets cut out and there’s a knocking noise or a ping. And when those analog channels are on normal scan they come in fine but the radio doesn’t revert when the channel I’m on starts to transmit.
The analog channels are a local PD and FD and there only receive channels
