NX-5000 Series, Q&A, Info, and details
Jay911
Silent Key (April 15th, 2023)
Bragg Creek, Alberta
Thanks, that's what I figured - I might be mixing up the two orders I just made, we also ordered a single-deck radio for another truck and maybe that was the one I got the basic display on. Much appreciated.
03msc
RF is RF
The Natural State
^ and in the setup you described I'd think you'd want to have that access on the display so I'd for sure want the 20R if possible.
harbor804
Hello all and I apologize in advance for showing up and starting with questions.
We are having a stuttering effect when our NX-5200 radios are on the scan. The radio traffic is broken and almost undiscernable only when in scan mode. When the radio is not scanning the traffic is perfect. I am new to the radio programming game and am not familiar with the different settings.
Would someone be able to provide me with some generic settings for the dropout delay, dwell, and look back times?
03msc
RF is RF
The Natural State
Describe in better/greater detail what you mean by stuttering.
harbor804
03msc,
Thanks for responding and offering to help. The communication is cut out or something similar to a tapping throughout the transmission. Once again this is only when on the scan mode. I have been focusing on the priority scans and am now considering removing them altogether.
03msc
RF is RF
The Natural State
03msc,
Yep, sounds exactly like it is supposed to operate when in priority scan mode and it is receiving a channel other than the priority channel (the drop-out is when it's checking the priority channel for traffic). If you turn off priority it should go away. You can also change your priority configuration as far as which channel is priority (i.e. currently selected channel, a specific pre-set channel, etc.
harbor804
Thanks, I went ahead and turned it off which solved the issue. Are there typical or generic number settings for the dropout and look back settings?
03msc
RF is RF
The Natural State
That's really just personal preference. I think there are some default settings in those fields but you can adjust them to whatever suits you.
W3AXL
RF Engineer
Indiana
Does anyone know how selecting a DMR talkgroup behaves on the radios? For instance, I'd like to have a single personality for each of the timeslots of a local repeater with selectable groups on each. Right now I've got a single personality for each timeslot, set up with "selcall on PTT" and set to a group ID. I'm wondering how this setup behaves with the "group" menu item and how/if the selected group ID persists for future PTTs. Ideally I'd like to be able to select the group ID once and have the radio continue to use it until I change it again.
The DMR function reference guide isn't too clear on what actually happens when you use the DMR Group menu item. Can anybody shed some light on this? I would very much like to avoid selecting the group ID I want every time I PTT.
KK6ZTE
California
It does not work well.
I have issues with it when I try to select a group dynamically using Group menu item. Once the timer runs out it'll revert to Selcall on PTT (if selected) or a non-existent talkgroup (if no Selcall on PTT). It won't stay persistent (at least that I could find) and it would require selecting the group each time. I've been unable to determine which Reset Timer affects this (but I can't stand ham DMR so I didn't put too much energy into it).
I suggest creating each personality with Selcall.
Wackodrumr
I've got the 5700 (main deck) & 5800 with full control head. Is there a setting to keep the main deck from overriding the secondary deck when it's selected?
I've got my radio programmed in conventional with personalities. When I want to hear the UHF side, my VHF will override the UHF even if the UHF is selected for transmit.
I was told a few Firmware versions ago that there was no fix for this. I'm probably a few version behind and wonder if it's been fixed.
kd4efm
EL98 Florida
I just ordered a triple-deck single-head configuration for my new fire truck coming in January, and I'm pretty sure I spec'd the basic head (KCH-19). Can someone tell me if the simultaneous receive/display functionality is available with the basic head, or should I be going with a full featured head (KCH-20R) instead?
Primary audio comes out of the speaker on the basic head unless you use external speakers on EACH DECK.
(same goes with the KCH20 with the KCT72 on the head)
To get full all deck receive you need to use external speakers on each deck (kes-5 with the KAP-2 or the mini speaker)
chrishoerner
KC3KSJ
Frederica, Delaware
Does anyone know if the nx-5200 / nx-5700 is part 80 certified? I can't find anywhere saying what its certified for. I think I read somewhere that they didnt do Part 95 on the uhf Models this time around..... didnt stop me from programming GMRS lol. I'd like follow the rules though on part 80.
