NX-5000 Series, Q&A, Info, and details
KK6ZTE
California
Now that’s what I’m talking about! Looks more like a hopped up TK-5x10 with that power cable and 9 pin accessory connector. Finally some real speaker output!
I asked about the low band RF deck.
They are waiting to see if a "large California state low band user" selects them to replace their aging TK-690's. If they do, they plan to go into production. If not, they don't see enough customers for low band to warrant a low band version. The TK-6110 is probably enough to meet market needs.
KK6ZTE
California
TK-6110 is EOL so there’s only small inventory left. I don’t see why CHP wouldn’t go for this radio.
kd4efm
EL98 Florida
FLORIDA DOT is another looker McK.
Sent from my SM-G965U using Tapatalk
W3AXL
RF Engineer
Indiana
Is there any good reference out there for programming DMR roaming? I'm working on a codeplug while my radio is in the mail and there is barely any info out there on what works vs what doesn't.
My ideal setup would be a roaming channel for each timeslot with the ability to select the active TG from a list (which I believe is possible on these radios). I've started dabbling with a DMR roaming system but there's a ton of settings and not very much explanation as to what they all do. We've got a really good statewide amateur DMR system and being able to roam around the state would be an excellent capability if I can get it programmed properly.
w8red
Knoxville TN
Did you hear Availability
Here ya' go, 110w RF deck. This is actually for the Kenwood VM series, but basically the NX-5000 with different software:
You hear street availability date on these ?
VHF, UHF high power? Probably soon, as in this year.
Low Band? Depends on said large low band using agency. The TK-690's are end of life'd as of August 2018. Replacement model is listed as "TBD".
kd4efm
EL98 Florida
Yeah, look for me to pop the word around the end of September, mid October.
I have a few customers who want in on it as well.
wx5uif
Broken Arrow, OK
So, 2.52 is the current firmware? My dealer is "positive" that 2.51 is the latest and greatest. Wish they would have some sort of download portal..
I am still getting most of the MDC burst and we only use BOT. I very rarely get a muted MDC burst. Plus, some departments strictly use EOT, so there is a definite need.
I agree, at least having the option to. Many users love kenwood but it's the first question we get asked about mdc or make it sound like the chirp they say.
We talked about it already, I will call again and try to get something but it then becomes a patent issue. Tell Motorola to end the EOT mdc and use only BOT.
Couldn't one mute the data completely or shorten it enough it doesn't interfere with motorolas dos mute. I'm sure a million names could be thought of to call it data silence, data recover etc. A short squawk would be nice even if it's slightly above or below theirs. While to me it isn't a issue it is users who constantly complain specislly dispatchers asking this fancy thing can't get rid of that sound, specislly on systems with a annoying astro, apx burst after mdc from M gear. I understand though the issues with licensing, patents so until then if any it'll be a oh well. It's nice to have that but for me it's how the equipment operates over all.
I agree bot is more useful than eot specially on butt key ups. Until something gives it away you have to wait for a dekey or voice beflre cells start ringing.
kd4efm
EL98 Florida
GO DIGITAL and you wont hear any chirps at all. This is 2018, Y2k was 18 years ago, let the 80's have it's MDC back. Get with the game, move to digital and carry on. It's an infrastructure thing, okay, but it's not that hard to migrate to Digital. This is called laziness. The argument about price is no longer a factor. (face palm)
People buy digital ready radios only to waste it away using it for just analog, because they want to hear the MDC. (awww that's cute) but they also want to ***** about it because they don't plan the operation of it correctly. (rant over)
GO DIGITAL, or just use the radio like it is meant to be used, Push to Talk, Release to listen, go home alive
AD0TY
Indiana
2.52 is current as of July. Tell your dealer to check the dealer tools site, or find another dealer. If you can’t get someone local to help you out, let me know.
03msc
RF is RF
The Natural State
Yep. Anyone who has the software should be able to download and apply the latest firmware through said software. The fact that they don't do it this way is pretty ridiculous, IMHO. If not via the software then it should be through some sort of web portal as you mentioned. Crazy.
kd4efm
EL98 Florida
Wish it was that easy, D1 is already slow enough as is, having it do the firmware updates also, (shouldering shrug) No thank you.
Beside, the firmware process is also a dealer payable process. You jack it up, it is not covered under warranty!
Just count the blessings.
APX8000
Sarcastic Member
AES-256 secured
Slight problem...NFPA mandates analog simplex for Fireground. Many departments use MDC as a way to identify what unit is transmitting in the event of an emergency.
Yes, digital is no longer expensive per se, but why switch if it works. Look at NYPD....
crazyboy
NJ
False, the NFPA does not mandate analog simplex. Read the entire document. The radio only needs to have an analog simplex channel in it. This comes up all the time on here. Not saying that’s an excuse to not make DOS Mute work though.
APX8000
Sarcastic Member
AES-256 secured
NFPA 1221
9.3.1.3 and 9.3.1.4
Unless something changed.
APX8000
Sarcastic Member
AES-256 secured
“Tactical on-scene Communications”...you can call it what you want but everyone in the fire service references it when discussing Fireground.
Before you go on rampage maybe you'd notice I said users. I stated I could care less for most part a bleep or burp in a data id.
Matter of fact I been pushing for digital.
Do you represent kenwood?
