NX-5800H programming cable question
wcu02mpa
Asheville,NC
I have an NX-5800H and have a question about the programming cable. I google search this and I find it calls for a KPG-46XM cable. I have a KP-46X Cable. Is there a difference between the 46X and 46XM??? I have never seen a 46XM. The radio is still in the box so am not yet able to try and read it. Thanks
kd4efm
EL98 Florida
It should have a micro USB pigtail on the front also. My 5600HF3 has one.
You can use either! Preferably the usb micro b, being usb native.
tlemke940
Lyons, OR
the kpg-46xm has a switch that makes it USB or uart the 46x is uart only. uart works but is really slow USB mode is like 5 times faster. if you are programming a single deck radio and not a multi-band radio just use the micro USB pigtail on the deck is is way easier and you don't need to buy a new cable. (assuming that you have a micro USB data cable) NOTE: make shure if you use the micro USB port use a data cable and not a charging only cable. chargeing only cable will not transfer data as those lines are not connected.
