NX-700 Audio problem
ctfd114
Marion, IN
I have a NX-700H that has no audio at all. HELP!!! Transmits and recieves fine, just no audio out of front speaker nor the 3.5 audio jack. Any help would be greatly appreciated!!
T0mSmith
Are you sure you are receiving correctly? Do you hear power on or control tones?
ctfd114
Marion, IN
I wasn't hearing anything at all. I found the problem tho. Took the radio apart, and looked at the jumpers inside on the board. Pins 4 and 5 need to be jumped in order for the internal speaker and ext speaker jack to work. It was originally jumped with pins 4 and 5, for PA use.
Could be a number of things, but you really need to provide some more information.
How did you determine it "Transmits and receives fine"?
Some things to check:
Maximum volume settings
Are the QT/DQT settings correct for both channels (analog)
RAN codes (NXDN mode)
Did you program the volume buttons?
Is it a new radio, or did you purchase it used?
