NX5000 P25 Group Call change from control head
crazyboy
NJ
I seem to be having trouble with changing the P25 talkgroup from the control head on the go. My DMR programming operates correctly, I can goto menu->call->group and change the DMR talkgroup on the fly. I am looking to do the same for P25. I have the correct P25 group list assigned to the personality, but when I go to menu->call I get a bonk when I select group. Is this possibly on P25, and if so can someone point me to items to check. As far as I can tell everything in D1N mimics the correctly working DMR system.
kd4efm
EL98 Florida
2 things, under channel edit;
do you have talkgroup strapped or select?
do you have a talkgroup selected for that channel?
if no, set it, then you will be able to change TG on the fly for that channel
crazyboy
NJ
Talkgroup strapped is unchecked.
Talkgroup is set to number 15 in the list that is assigned to that personality and works correctly.
kd4efm
EL98 Florida
Any luck on this?
I have been on a major installation project and wanted to follow up.
Any chance you can send your dat file for me to look over?
crazyboy
NJ
Any luck on this?
I have not made any progress on this. Sending over the file now.
