O3 head programing
Cowley639
Arkansas City, KS
Hey everyone,
I’m considering switching my remote head XTL5000 over to an O3 head. My question is; how is the radio programmed? Do I just remove the O3 head to program using my regular programming cable?
Also, I’d just need the dash mount speaker/ignition cable? I wouldn’t need the red speaker/power cable that I have on the remote head now?
n3obl
ØAES-1056
PA
You can program from the rear connector via USB.
Cowley639
Arkansas City, KS
Also; confirming I just need the XTL5K brick with TIB. O3 head, and rear accessory plug (for the speaker) correct?
Sorry for the ignorance here. Never delt with a O3 head before.
I’m in the process of switching vehicles, and no longer have room for a full size head in my console/dash. Hoping to mount the brick behind the rear seat, and then just have the O3 to mount up front.
K2NEC
5F6
You also need the radio power cable but I assume you'll already accounted for that. If you dont plan on using ignition sense, you can just snip that wire off and just use it for speaker output.
Cowley639
Arkansas City, KS
Yes I have the power cable already as well as the accessory cable. The 5000 is currently set up in dash mount configuration with the O5 head.
Any specific considerations I need to keep in mind when upgrading to the O3? Firmware, etc?
dickie757
Resolved
Out of range
Be patient and let FlashZap do its thing. You may have to power cycle and remove/replace ignition power a couple times. Be patient. If you do an action, and nothing happens, wait about two minutes before undoing or doing something else.
Do you have PMLN4958A? O3 cord by itself prob not long enough.
