Odd antenna Design
Laxplurr06
Boston, MA
Today I opened an 800mhz antenna that was not performing as well as I had hoped. I found this inside the tube and was hoping that someone would be able to explain to me how this antenna works.
The center conductor is connected to the brass tube that is located in between the others, and small piece of coax at the top. The outer conductor is connected to the other brass tubes as show in the picture above. The center conductor is indicated by the blue lines, and the outter conductor by the red lines.
K
kb0nly
Guest
Yep collinear...
A collinear antenna is just basically stacking elements of a measured wavelength to get gain. Its like having a bunch of 1/4 wave antennas stacked to make one big antenna.
Laxplurr06
Boston, MA
Is a certain amount of quarter waves needed, or could they keep being stacked on top of each other to get more gain? I am curious because I would like to try and make one for 470mhz, or possibly try and increase the gain on this one.
mancow
N.E. Kansas
That page I linked to has the details on how to build one and the relationship between number of elements and gain.
mpddigital
SW GA - 30 years South of Atlanta
They are not hard at all to construct but length of the elements and construction are critical to getting the antenna turned to the freq you want to operate. The ones we have used operate best on a fixed frequency rather than using it over multiple bands.
lmrtek
collinear designs use electrical 1/2 wave elements stacked
A doubling of the amount of elements will give a 3db increase at the expense of course of vertical beamwidth
kb2vxa
Banned
Point Pleasant Beach, N.J.
There's more to it than simply stacking elements. In between are phasing stubs to keep the active antenna elements in phase or they would cancel each other out resulting in no gain.
prcguy
This design just stacks 1/2 wavelengths of coax (1/2 wave w/velocity factor) and the phasing is done by swapping the center conductor and shield at every element. There is usually a 1/4 wavelength coax balun at the feed and a 1/4 wave whip on the top of the last element.
Because the phasing and distance between elements is not optimum it takes eight half wave elements to give about 5dBD gain where it only takes 4 elements in an exposed dipole array to get 6dBD gain.
prcguy
WQFM513
Hermiston Oregon
i recently built one for my gmrs repeater. used schedule 40 pvc as the radome. the wind took it down pretty quick. 70+gusts. i decided not to repair the collinear and went with a simple whip type with a ground plane. another one i also made.
my measurements brought the 9db collinear to 2100mm (6.8 feet) and it worked great. nice gain, swr at 1.2:1 and it could "hear" stations very clear, loud, and out pretty far.
½ wavelength of coax = 300 / F / 2 * V
Where F = Frequency in Megahertz
V = Velocity factory of Coax
300 / 462.6250 / 2 * .66 = .2139 meters or 213.9 millimeters
1/4 wavelength radiator = 300 / F / 4
300 / 462.6250 / 4 = .1621 meters or 162.1 millimeters
213.9 X 8= 1711.2
162.1 X 2= 324.2
1711.2 + 324.2 = 2035
2035 + about 2 inches of radome length for comfort = 2100 mm
2100mm converted to inches =82.67
82.67 inches = 6.8 feet
prcguy
You show 8 1/2 wave elements, that would make around a 5dB gain colliniar not a 9dB.
prcguy
213.9 X 8= 1711.2
162.1 X 2= 324.2
prcguy
One of my sources is the older the ARRL antenna handbooks which published the internal construction for the original Phelps Dodge Stationmaster antennas which became Cellwave then something else. I've also disassembled several 5dBD Stationmaster antennas which have eight half wave coax sections soldered with opposing center and shield plus the 1/4 wave sections on the top and bottom, exactally like the ARRL antenna handbook.
How tall was your Antennex? If it was a 5dBD model it would be about 7 1/2 ft tall. If it was shorter it was not a 5dBD collinear antenna.
prcguy
my sources figures said 9db gain. the one i built did out preform my 5db gain antennex omni. just couldnt handle the wind out here.
WQFM513
Hermiston Oregon
yes it is an nmo mobile with a black coil between elements. it is 32 5/16 oal. it sure seems to be a 5db gain antenna. works as well as advertised.
i can activate and receive the repeater between royal city and yakima washington from my current location. thats roughly 65 air miles. 45 watts 462.700 standard gmrs offset. about 5 feet above ground level.
