Odd SWR variance
altermanncam
Bloomsburg, PA
I just put a new CB rig in my car recently. Cobra 29 LTD Classic with a Wilson Little Wil 3' antenna. Took it to an open area and properly calibrated the SWR. Great readings across the entire band with an SWR of ~1.3 at most. What's strange is that a few times now I've gotten in my car, powered up the radio and noticed my transmitting signal was weak. Antenna light illuminated. In SWR mode, the needle pegs. I recalibrated and it was fine. Another instance I just drove out on the road and it was fine. Another time also I simply shut the radio off and then back on and it was OK. It seems to be random, but the issue never persists.
Also: Checked antenna coax and no part is damaged or kinked. Also lengthwise the coax it isn't coiled up at any point.
This is my first CB so I'm a rookie. Any information would be appreciated.
N8IAA
Fortunately, GA
To truly see what the SWR is, use an actual meter for that band. That would be one between the radio and the antenna. Not in the radio itself. Then you can trim the antenna to get the best SWR over the whole band.
Larry
K5MPH
Brownsville Texas,On The Border By The Sea.
It sound like you might have a short in the coax itself check for any weak area's in the length of the coax from end to end and also is the antenna Mag Mount or trunk lip Mount and if trunk mount make sure your trunk lip is grounded good.......
TheSpaceMann
Could be an issue with the radio. I once had a CB with the same problem. I discovered that there was a loose connection on the back of the SO-239 inside the radio!
