FrankJ - It sure is a lot of fun. Here's some quickie starting points for ocfd's using 300:75 ohm baluns:
Typically they are fed 1/3 of the way in (0.333) of the total calculated half-wave length as opposed to the center-fed. They work well on *even* harmonics. (2nd, 4th, 8th harmonic - avoid the 6th however)
In order to use most of the antenna as an ocfd, pull one extension out to 40 inches, and pull the other out to only 20 inches. It's still not a great low-band antenna, but it sure beats ducks. Works ok higher up the spectrum but I favored the following two dimensions:
14 inch short leg, 28 inch long leg. Nice low swr at 125 and 135 mhz. Works great at higher freqs but all I have is an s-meter to go by.
I am also happy with 9 inches and 18 inch legs.
In your case for mil-air, I'd be interested in comparing your 18" dipole to an ocfd cut for your lowest freq of interest at 225. Maybe extend one leg to 16 3/4 and the other to 8 1/4 to compare how well it works up to 400 mhz..
Didn't mean to preach, but I'm so jazzed with mine I had to let it out!
