Official BCD996T Post Release Thread
MacombMonitor
STiMULi said:
BTW that was my 12 hour review of which I have actually operated the scanner for 3 of them. Most of that was spent changing the color back and forth from Red to Green to see which one I like most :)
:lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol:
Finally an honest review!
garys
Central Texas
STiMULi said:
I had this BCD996T plugged in all night and it won't hold a charge! Everytime I unplug the power the scanner goes off!
Now, THAT'S funny!
Gary
scannerfreak
Well Known Member
Indiana
ruarc said:
OK, I asked this is a new message, but no good answer there, so I'll try again here..
WHAT are the TG restrictions in the 996?
The docs say 250 TGs per system, but nothing more.
The 396 only allowed 20 TGs per group, but is that the same in the 996,
and is there still a 20 groups per system restriction??
This was answered in your first thread:wink: , 250 talkgroups total, 20 groups, doesn't matter how many in a group as long as you dont go over 250 total..
h8tdigitalradio
Uniden Beta Tester
Six Feet Over
ruarc said:
WHAT are the TG restrictions in the 996? The docs say 250 TGs per system, but nothing more.
You answered your own question. The "docs" are correct.
Actually, the amount of TG's allowed is 200 in a group. The Group can have any size up to 200, Conventional, or Trunked TG's.
No. Now you can have up to 250 TG's in a Group.
Yes.
HTHs
73
Dave AKA The Tripzter
teebee
Lake Charles, LA
I am trying to find the setting to set the scanner to search and turn off CTCSS tones for a conventional system/group. The only option setting I find is where you can select this for each individual channel. I want to search every channel with one setting.
b52hbuff
Points of Interest Limits / Impact?
So what is the limit on the points of interest, and other GPS points you can enter into the 996?
Do the points of interest take away memory used for channel memory?
UPMan
In Memoriam
Arlington, TX
Each location takes up a channel memory. You can put in up to the limits of the scanner's total limit of 6000 channels.
b52hbuff
Thanks for the response, may I suggest an addition to the Wiki and perhaps the owners manual?
ofd8001
Louisville, KY
What happens to systems that are turned on and off by GPS when the GPS signal is lost, such as going into a concrete parking garage? Does the system get turned off, or all the off systems get turned on? Or do the systems remain in whatever state they are in (on/off) until the GPS signal is re-acquired?
UPMan
In Memoriam
Arlington, TX
Systems remain in whatever state they were in. Note that GPS performs a temporary lockout on systems as it moves out of their set range. So, power cycling w/no GPS will result in those systems being unlocked (however, if their SQK is disabled, they will not be scanned).
kikito
North Pole, Alaska
h8tdigitalradio said:
The Group can have any size up to 200, Conventional, or Trunked TG's.No.
I thought the 200 limt was ONLY for TGs. Conventional was not limited in the radio and only on Butel software it limits you to 200 conventional.
UPMan
In Memoriam
Arlington, TX
Correct. The scanner can take up to the limits of total channel space.
h8tdigitalradio
Uniden Beta Tester
Six Feet Over
Hello,
Yes. What I meant to say was you can program up to 200 Conventional Frequencies per group, (250 for BCD996T) and 20 groups for a possible 4000 Conventional Channels in a system.
73
kikito
North Pole, Alaska
Hello,
73
That's the thing, you can have MORE than 200 conventional frequencies in a group.
As far as I know (and I think that's what UPMan confirmed), the 200 on the BCD396T and the 250 on the BCD996T is only for talkgroups.
dbrown2
Greer, SC
Waiting on my Scanner UPS says tomorrow.. I downloaded the UASD soaftware and wanted to know if there is way to import data from radiorefernce.com web service or CSV?
If it will import csv I could write something to parse the xml web service from RR to create a csv (unless that program is already written)
goggles
Blue Mountain, Ontario
Im new to this site and this is my first post, I picked up a new 996T a few days ago in Toronto, after going through the thing, I said to myself, yep, its alot different from my 780XLT then I found this site and made a donation because Im going to need some help eventualy.
hotdjdave
K9DJW - Senior Member
The Valley (SFV), Los Angeles, CA
Welcome
Welcome to RadioReference (aka RR). You will find a wealth of information and friendly advice here. :)
