Official BCD996T Prerelease Thread
Jay911
Silent Key (April 15th, 2023)
Bragg Creek, Alberta
For what it's worth, all the people who are saying "it's impossible to alert on more than one channel simultaneously" are wrong. I have a fleet of Big M radios in various bandsplits which have multiple tone-sets on each of 16 channels, and if they hear both tones (any fraction thereof - doesn't have to be the full 1 sec/3 sec), they alert. Period. The very same logic could be applied to the scanner, if someone would bother coding it that way.
Now, if you want to argue that it's possible you won't catch the alert because you're on a different channel, then that's where the "duh! obviously" comes in. I don't think anyone in this conversation reasonably expects that "alert" means "priority receive and alert", except the people saying "you can't do that". This is akin to saying that emergency alerts is broken because you don't catch every emergency-button-press on system xyz, because you're not even scanning it at the time the button-press comes across.
I believe that most people who want multiple toneout options in these scanners want them to work like I describe here: If when scanning, channel X is received and there are tones on it, compare the tones against the tones entered in the tone-out entries for that channel. If the tone being heard matches, continue the tone-out process (listening for 2nd tone, sounding alert, etc). Otherwise, and after the tone-out process in any case, resume normal operation (staying open/hanging on channel X until the delay/squelch conditions are matched).
That's not too hard to fathom, guys, and not much to ask, either. Anyone who expects that the scanner, when it's off-channel or even off-system, is going to have any hope of catching an alert going on on channel X, doesn't understand how scanning radios/receivers work in the first place.
The majority of scanner hobbyists, IMO, would want tone-outs in the manner I described above, simply to provide an additional alert that "hey, this department has a call going on". So it doesn't matter if every alert is captured or not. Anyone who is trying to use a scanner as a primary means of being called to a job are missing the point of the scanner. Furthermore, people in that position should have pagers, alerting radios, or other department-issued equipment to do the mission-critical dispatching that's required for them. If your department hasn't issued you a pager yet, perhaps they have a reason for not wanting you to respond to calls at this time... give THAT some thought.
And now, know-it-alls and wannabe experts, let the flaming commence!
rdale
Lansing, MI
" (any fraction thereof - doesn't have to be the full 1 sec/3 sec)"
The scanner doesn't just do 1/3 seconds like the Motorola you refer to... It does 8 seconds, it does 2/2, it does any combination that's out there...
Jay911
My point there was apparently obscured. The "default" QCII standard is 1 second A/3 second B tone. My radios will decode on any fraction of A/B that it receives. And as a matter of fact, the Minitor II's default settings specify that the intermittent (or steady, depending on the alert preferences) tone lasts for the length of the B tone received. So if it only receives 0.3 sec B tone, that's all it beeps for.
The point I was trying to make was that the Motorola radios will alert on any amount of A/B, so long as they are in that order without gaps, and the scanner should be able to do the same if it does not do so already.
The one time I bothered to try the scanner during a known pager test, it waited for the full 3sec duration of the B tone before doing the scanner's built-in alert. Granted, that may have been original firmware, I forget at this point. My point stands... if tone A has been met (of sufficient length to determine it's a tone and not something else), then a minimum amount of tone B (again, just enough to understand it's tone and not voice/etc) should set off the alert.
oregontreehugger
PNW
Jay,
The way you described is great -- it would be nice to have a setup where the scanner checks for tones, then if they don't match your list, goes back to regular scanning. Or you could just leave it on a single channel and have a quasi-pager (as it is now).
Scanners are nice for keeping up with things, but for real-life situations I wouldn't want to bet someone's life on them. Let the municipalities and departments buy actual radios and pagers for their members.
ofd8001
Louisville, KY
I agree with Jay and the Tree Guy- you wouldn't want to use a scanner as your sole mean of alerting firefighters. It's better to use the equipment designed for that purpose. Kind like using a screwdriver as a chisel. This is a fire chief with over 30 years experience talking.
I've been told by some folks, but I won't say this is gospel - the 3 second part of the tone pretty much dictates how long the pager beeps. After tone B stops, the beeping stops. The actual times really don't have to be 1/3.
DaveIN
Founders Curmudgen
West Michigan
I'd like to see frequency hit logging on the UASD Extended Online Control to go along with the talkgroup logging for the 996.
Voyager
It does work the way you described. That was part of the first firmware upgrade that wasn't quite ready when the scanner was released. Paul mentioned very early on that it would be a firmware upgrade to enhance the FTO feature would be coming soon.
The problem, and why people are saying you can't do it, is because you lose reliability. As it stands now, the scanner will alert if it can decode the tones at all. There is no possibility of missed calls due to being on a different channel. It's technically possible to do 100 different tones on 100 different frequencies - as long as you don't mind missing pages.
Motorola even has a disclaimer that won't guarantee the alert feature if you are scanning - even if only scanning two channels. The Min V may have changed that - I'm not sure.
Joe M.
TinEar
Glen Burnie, Maryland
You know what I'd like to see Uniden (or anyone) make....a base scanner. Not a base/mobile scanner....a real, honest-to-God base scanner. It would have
1. A good, hefty size.
2. Decent sized buttons spaced widely enough so that you didn't have to have dainty little female fingers to press only one of them.
3. A knob or switch for each function rather than multi-function knobs and multiple key presses to accomplish the most simple things -- with enough knobs and buttons and switches so that each function had its own. Have 40 of the damn things if necessary with a nice, little printed label under each.
4. Audio circuitry at least of the quality produced in radios 30 years ago which, somehow, has been erased from electrical engineers' collective memories and is no longer made.
5. A front firing speaker of adequate size to be able to reproduce decent sound quality that can be heard from across the room and still sounds like a human's voice. Let's face it; you already have to buy a separate speaker for today's radios because the mini-replica-psuedo-quasi speaker built in can't be heard anyway. We've built these amazing new scanners that you can't hear. How much sense does that make?
There are many, many of us that use scanners only at home. And if I ever did need to take it into the car or truck I don't care if it takes up the whole darn passenger seat. The trend in electronic manufacturing has been to make things smaller and smaller. I, for one, sure appreciate what can be crammed onto a chip in the radio to provide various functions that we get to enjoy in the new radios. That's just fine for the "inside" of the radio. However, the things that must be used by the operator on the "outside" of the radio don't need to shrink along with the circuitry. And that's what I want someone to build. I love what I'm reading about the 996T. I just wish it was in a box about about 18 inches wide and about 8 inches tall (Okay, so I exaggerate a bit on the size), with a six inch speaker and had knobs and switches and buttons all over the place. Oh yeah...and a big, bright display. And most definitely it would have the transformer built into the radio so you could just plug it into the wall without a wall wart. Now *that* would be a scanner.
JGP
Franklin, Wisconsin
TinEar, maybe UPMan will have a scanner like this built and make us all happy. This would be worth the BIG $$ to buy. Not everyone likes small.
Joel
PJH
Not unlike my current post elsewhere about the 9000. An excellent scanner that I can't give up due to its excellent sensitivity where I live. The 780 and newer ones just don't compare to it...unfortunately.
n4voxgill
Silent Key
New Braunfels, TX
TinEar described a Pro2006 with its permanent AC line cord. I would be just as happy with one that can only be programed via computer and free up the front for a bigger dispaly by doing away with all of the buttons. I agree with the big speaker.
baybum
Howard County
I agree, Al, 100%.
A base is a base, a mobile is a moble. And there is a reason they used to be different.
Because some things shouldn't change. Just like the old CB's. A base has big knobs, a big readout, speaker in the front, and it looked good sitting in the shack.
I'd like to see the new Uniden base in a wood-grain enclosure. The front panel read-out should be 3"x3" at a minimum.
Computer programming is a great enhancement these day but should not be a requirement.
Computer control should never be a requirement. You should be able to hit a button, or turn a knob to accomplish most tasks.
I don't care if the damned thing is as big as a microwave oven.
I want to hit a button and make things happen, and I want a full, rich loud audio output.
Mike
Dubbin
Findlay Ohio
Well I see that this thread has turned into another useless thread that has many posts that has nothing to do with the BCD996T. Come on guys keep on topic here.
Julian1
Birmingham, AL
996 Uniden / Detachable Front End??
UpMan,
What is the chance you could build w/ a detachable front end. Cars have less and less room in them for mounting.
A detachable front end would enable to mount the front end as a control head.
This would be similar to what ScannerMaster has done with the 780 and now 796.
Also......more sensitivity on 800. When I drive through downtown Atlanta I hit dead spots that sound awful. Using an Antenex ABSCANC which I know is a compromise antenna.
Thank you for your posts and updates on the new things from Uniden!!
Best Regards,
Julian
AndrewC75
Kennesaw, GA
Julian, beleive it or not, I think what you want is LESS sensitivity on 800. Well, not really. What you really want is a better front-end that reduces adjacent channel inferference, intermod and such. As you know, I live in Atlanta too, and I have the same problem. What I'm 99% sure it is, is that all of the other RF in downtown Atlanta is causing the radio to desensitize - in essence, the radio is getting overloaded - and can't really "pick out" the 800 Mhz transmissions from the rest of the noise. The same kind of thing happens to me in certain places practically in the shadow of an 800 Mhz antenna site (i.e. Barrett Parkway in the shadow of Kennesaw Mtn) where there are cell towers and business radios overloading the scanner.
Try turining on the attenuator for your Atlanta system the next time you drive through downtown. I think you'll find the improvement remarkable.
crony803
Why not?
Jay said:
The majority of scanner hobbyists, IMO, would want tone-outs in the manner I described above, simply to provide an additional alert that "hey, this department has a call going on". So it doesn't matter if every alert is captured or not...
This is exaclty what I'm talking about. I'm not always paying full attention to my scanner even when I hear the tones going off. I've got a pager, so I can rely on it for most of my calls. However, my department is at the edge of the county, and my pager doesn't always pick up the signal. (Let's face it, a minitor on LOW band can't possibly get bang-up reception in that little box). However, my car and home scanner anntennas do a MUCH better job (I'm using an antenna specifically for 39mHz) for picking up the signal.
We have somewhere around 18 fire districts in the county using this frequency, and I'm only intersted in a total of 4 of them (ours, and the three neighboring for mutual aid) as well as the local rescue squad for manpower assist and accident extrication. I would like to have that additional "alert" to keep me aware of the calls in which we may be called in to assist.
Sometimes I don't want to hear everything going on, so I may want to limit scanning to just those items I want to be alerted on (Bethel, Clover, York & Newport Fire, and River Hills EMS). And I'm only talking about two channels- one for fire and one for EMS. With the scan rate of these scanners, I think it's realistic that you could even get 99% of the tone-outs, depending on how they programmed this feature in- check the tones and if it doesn't find a match, it goes to the next channel and so on. As long as you keep the number of frequencies down, it should work. Heck, even if they can't do it that way, I'd still like the "alert" if it hears the tones. It wouldn't be anywhere near reliable, what does it hurt to have the "beep, beep, beep" if does detect the tones? It doesn't.
pcfn360
Auburn,MA
996dt
Will this unit be already configured for the trunked re-banding or will this also require a reflash and reprogramming?
Ed
UPMan
In Memoriam
Arlington, TX
There is no way to know the answer to this at this time. It depends on whether any rebanded Motorola systems have gone live, how long they have been live, what control channel changes were made, and many other factors (the same factors that will determine whether it can be done for any scanner at all).
ofd8001
Louisville, KY
Monitoring Several Departments
What kind of pager are you now using?
Motorola III, IV and V can be activated on at least 4 tone groups, if that's what you now have.
I suppose we could get Uniden interested in doing this kind of thing, but I'm sure they would like to hear from a lot of us who really want that feature, before they put a lot of development time and effort (but mostly money) into this.
