There is no column called "
column ""MO" class usually with >1 in the "UNITS". I left some punctuation out that made you think there was a column with that name. Silly me.
Class = MO
Units = 160
They are licensed for 160 radios in Location 4, at 110 watts ERP. Those 4 frequencies on the left are most likely the inputs. The frequencies higher up in that image (that I clipped away to avoid ongoing confusion) with the ERPs >200w are the outputs. If you notice, frequencies are duplicated between classes & locations.
If you were a premium subscriber, I believe they coordinate which input goes to which output for you. I'm not. Don't know. If you were so inclined, and could recieve those channels locally, you could find out in very short order which goes with which.
Repeated channels are coordinated and offsets can vary based on each license application, it's not like 800 or 900 bands where offsets are hardcoded into the radios.
If you needed the inputs for authorized use, you should be able to contact the system administrator to find out which input goes with which output. If you're just looking to scan away, the information is right there. A little bit of work can lead you to the correct pairing. Listening to repeater inputs is usually much harder, and will result in you hearing less than you would if you were on the repeater output.
