I'm in Hilliard so when i am in town i will help as much as i can
For NW Ohio area DSDPlus users:
Please check and see if you can pick up a digital signal on:
461.5625
464.15
If so, please report any/all information you can regarding the type of signal, any system/site IDs, neighbors, color codes, RANs, channel numbers, etc.
I believe those two frequencies to be an active part of a trunked system (that isn't necessarily based out of NWOH) but will not say anything further until I get confirmation from NWOH users that the signals are eminating from that area. Unless I'm wrong, they are probably coming from the Toledo, Napoleon and/or Findlay area and/or the southern tip of Michigan.
Tnx
Mike
You sure do get around! Thanks
Mike
One place where 461.5625 is used is as a conventional DMR frequency at the Toledo Museum of Art [License WQE316]. Color Code 13, Group Call 11. That's all I have on it for now.
I have got this about 3-4 months ago.
464.1250 Sys 289 site 11 nx 4 ran 11
Signal was weak so I would say it is in Michigan
I am willing to help but have no experience with DSDplus. My computer is Windows 10 and have the SDRplay RSP2.
If you're willing to lend a hand in using DSDplus, I can look around the extreme southwestern Ohio area.
Ok, that's definitely not what I had in mind. I guess I should be more specific:
System ID: L289
NXDN 48
Site 11 CC: 464.15
Site 13 CC: 461.5625
Mike,
I agree that site L289-11 is in Toledo. Earlier while in Perrysburg I had a very strong signal on 464.1250. Now at home, which is southeast of Toledo, I get a decent signal but not as strong as it was while in Perrysburg.
Running DSDPlus I am getting the following as neighboring sites
L289-3 CC=92
L289-4 CC=126
L289-12 CC=681
L289-13 CC=631
L289-21 CC=900
As far as 461.5625 I was able to get a weak signal while in Perrysburg. At home I cannot get anything. That would leave me to believe that it could be in Findlay.
Hold that thought. Somebody might be able to help you with DSDPlus and SDRPlay (presumably with SDRuno software). I can likely help you too, but would not be able to get into something that involved til the weekend.
I'll try to make up some instructions in the meantime that I can post (regarding DSDPlus) for the benefit of anyone reading this thread who is wanting to download / install the free version of DSDPlus from www.dsdplus.com.
Basically, I think you will need to install both DSDPlus and VB-Cable -- unless SDRuno supports some virtual audio piping of it's own. And I know that in SDRuno you would have to click EXW in the receiver control and then unselect DEEM (so de-emphasis is turned off).
SDRuno <-- VB Cable --> DSDPlus 1.01
DSDPlus 1.01 and DSDPlus 1.101 DLL Files zips ( https://www.dsdplus.com/download-2/ )
VB-Cable ( https://www.vb-audio.com/Cable/ )
You would download the two DSDPlus zipfiles and unarchive them into a folder that you can easily access such as in C:\DSDPlus . Then you would download and install VB-Cable. Then you would turn off DEEM (de-emphasis) in SDRuno. If you can do those three things you are well over halfway there. The rest is all just learning how to adjust SDRuno correctly and make it output audio to the virtual cable, and then learn how to fire up DSDPlus so that it pulls in the audio from the same virtual cable.
Like I said, too involved for me to personally spend time on it now. But that will get you started.
mike
belvdr said:I will take a look at this tonight or tomorrow. My neighbor needs some help first and that's what neighbors are for.
Thanks for the quick write-up. I'm tech-savvy (not radio savvy) so this should be the easy part for me.
@mtindor Thanks for the help. I was up and running within a minute or two. I'll start scanning and see what I can find.
+DMR slot2 BS DATA DCC=5 Idle
+DMR slot1 BS DATA DCC=5 CSBK
+DMR slot1 BS DATA DCC=1 Data Header
+DMR slot2 BS DATA DCC=1 Idle
+DMR slot1 BS DATA DCC=1 CSBK
Ran across this on 451.010. I do not see this in the database nor on another SW Ohio monitoring group's list (monix.net):
DMR:
Current network: 113
Current site: 113-19
Neighbors 1, 2, 12, and 17.
DMR:
Another on 451.500:
Current network: 128
Current site: 128-2
No neighbors listed.
Again, not radio savvy, so if this is useless, let me know.
